A1706 No power
  • madjid911
    • 396
    • France
    A1706 No power
    Hello, I have a macbook a1706 (820-00923-A) that does not turn on, the 20v ubc triggers but no power consumption, no short and no liquid damage, PPBUS_G3H: 0V15 (16mohms no short), U7000 is well powered by the 20V, I looked at everything around the ISL9239 chip the resistors are good, so I replaced the chip twice but the result is the same, my skills stop there can you help me please?
  • mon2
    • 14271
    What are the voltages to ground of the following points?
    TBA_VDDA
    TBA_VDDP
    TBA_AUX_DET
    TBA_CSI_P
    TBA_CSI_N
    SMBUS_SMC_5_G3_SDA
    SMBUS_SMC_5_G3_SCL
    • madjid911
      • 396
      • France
      TBA_VDDA
      TBA_VDDP
      TBA_AUX_DET
      TBA_CSI_P
      TBA_CSI_N
      SMBUS_SMC_5_G3_SDA
      SMBUS_SMC_5_G3_SCL
      TBA_VDDA : 5V12
      TBA_VDDP : 5V12
      TBA_AUX_DET : 4V94
      TBA_CSI_P : 19V77
      TBA_CSI_N : 19V77
      SMBUS_SMC_5_G3_SDA : 3V27
      SMBUS_SMC_5_G3_SCL: 3V27
      • mon2
        • 14271
        These look ok to me. Flux and remove the fuse @ F7000. Power up again with the adapter. What voltage do you measure at the removed fuse F7000, pcb pad #1 = ISL / producer side of this power rail.
        • madjid911
          • 396
          • France
          F7000 PIN 2 : 0V700 increasing
          pin 1 : 0V
          • Danielreinaa
            HELP need password bios Macbook A1706
            by Danielreinaa
            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
            09-07-2024, 03:47 PM
          • moderator
            A1706 - emc 3107 bios
            by moderator
            a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
            Serial number is C02STA7EHF1P
            its A1706 - emc 3107...
            05-17-2024, 07:00 AM
          • capon5153
            Macbook A1706 works perfectly but no data on USB C
            by capon5153
            hello,
            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
            06-22-2025, 09:42 AM
          • Arshad alam4659
            a1706 smc program
            by Arshad alam4659
            I have a1706 820-00923-a, the smc in this board is bad (980 yfe tm4ea231) I have a new smc but the problem is how to program this smc, does anyone know about it pls help
            01-31-2025, 07:55 AM
          • Arshad alam4659
            macbook a1706 in dead condition
            by Arshad alam4659
            today i received a macbook a1706 in dead condition When I removed the battery the laptop started up i connect the battery again and press power button but laptop not turn on
            I did smc reset and the laptop started . I have to reset the SMC every time to turn it on. It does not turn on without resetting the SMC. Sometimes it starts without resetting the SMC.
            someone guide me what is the problem bad smc or anything
            12-19-2024, 02:41 AM
