Hp g6-1350ep
  • Luís Amaral
    • Nov 2013
    • 78
    • Portugal
    Hp g6-1350ep
    Hi, i´m working on a G6 that keys "2", "w", "s", "x" do not work, already change KB controller and keyboard, model of the board is :
    REV: D
    DA0R23MB6D1
    Anyone have the shematics or help do solve this issue !!!
  • kuldeep
    • Sep 2013
    • 30
    • india
    Re: Hp g6-1350ep
    pls upgrade EC Bios...!! if no change check all Keyborad input & Output signal Track KB controller to KBD Connector...!!
    • Francisco.s
      • 686
      • Spain
      Re: Hp g6-1350ep
      REV: D
      DA0R23MB6D1
      Here you are.
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        Re: Hp g6-1350ep
        the 4 keys are on the same matrix could be just the keyboard.
        • trebo
          • 514
          • Wales, UK
          Re: Hp g6-1350ep
          or maybe a clean of the K/B socket with some isopropyl
          and a close inspection of socket for damage also
          • Luís Amaral
            • Nov 2013
            • 78
            • Portugal
            Re: Hp g6-1350ep
            The keyboard is fine, thanks for the shematics already update bios, later i will give some news
            • Luís Amaral
              • Nov 2013
              • 78
              • Portugal
              Re: Hp g6-1350ep
              Problem solved, thank you for help me to solve this, the problem was the trace from KB (MY5) to CN4 (Keyboard Con.)
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Re: Hp g6-1350ep
                Now that's a weird one. Did it have a liquid spill by any chance? Anyway, kudos for fixing it.
                A working TV? How boring!
                • Luís Amaral
                  • Nov 2013
                  • 78
                  • Portugal
                  Re: Hp g6-1350ep
                  Yes i think so... it seemed to caught some liquids and have been cleaned and then come to my store because the four keys do not work
                  It is my opinion.
                  • dj_ricoh
                    • 2073
                    • uk
                    Re: Hp g6-1350ep
                    I`m wondering how did you know that was the problem?
                    your talking about mV or you find it with the scope?
                    • Luís Amaral
                      • Nov 2013
                      • 78
                      • Portugal
                      Re: Hp g6-1350ep
                      With the help of shematics i tested all pads with multimeter on test diode from CN4 to keyboard controller, the one that does not have continuity was MY5 that goes to pin 44 of keyboard controller.
                      • master3112
                        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                        by master3112
                        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                        10-29-2024, 09:32 PM
                      • ronnygracias
                        Help with freemotion incline trainer with controller comm error
                        by ronnygracias
                        The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                        11-04-2024, 01:32 PM
                        Tankless hot water heater controller board not powering up when power is applied
                        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                        However I would like to know if I could figure what happened to this controller board if possible
                        Tomorrow I will take some better pictures of both side of both boards
                        The...
                        12-09-2022, 09:14 PM
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                        Modifing a Battery Spot Welder because of Controller Issues
                        I keep having the same exact issue with these battery spot welder controller boards
                        They either do one of two things
                        One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                        Or
                        The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                        This...
                        10-12-2019, 08:51 AM
