Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
  • m1ch43lzm
    • Mar 2019
    • 1064
    • Peru
    #41
    Looking back at your pictures, could you post an updated picture of this area?
    Are those caps highlighted in green missing? Those are needed for EDP signaling, CG13, CG14, CG15, CG16, CG17, CG18, you won't get a picture without those...
    The caps in red are also badly soldered, but unrelated for now
    Resistance looks fine on BL_ON (50.5k), now fix those missing caps for EDP signals, your customer sure made a mess on the board
    • Acnologia
      • Dec 2016
      • 429
      • Poland
      #42
      Click image for larger version  Name:	IMG-20250610-WA0000.jpg Views:	8 Size:	137.5 KB ID:	3656434
      Yes, but what can you do ? Customer is always right. To my understanding he will not bother , to even pay for that service. So most probably will reject the repair and i will keep the laptop or something for labour. So for now , i would say i am repairing it for personal knowledge and gaining experience.
      The 'green'eveything is missing , the red is a little bit better...
      So most probably i need to order parts for the CG13,CG14 , from aliexpress....
        • 22155
        Originally posted by AccountSaver
        Yes, but what can you do ? Customer is always right.​
        • Acnologia
          • Dec 2016
          • 429
          • Poland
          #44
          Originally posted by SMDFlea
          hahahaha <3
          • m1ch43lzm
            • Mar 2019
            • 1064
            • Peru
            #45
            Don't want to blame anyone yet, but that kind of damage could be done either by the customer himself, or "his friend" that will do it for cheap but ends up making it worse
            Always a good idea to take pictures before a repair, to cover yourself in case something goes wrong with the customer
            maybe he thought that there was a short and ended up removing caps at random, then replaced the LCD cable (or the whole display assembly, from the AMD version), then gave up after making it worse
            Or the opposite, the original screen could have cracked (or just didn't show a picture), then he/"his friend" replaced the whole display assembly with one from the AMD E15 gen2, and not realizing his mistake made it worse
            I'm making hypotheses here on what happened here
            Don't you have electronics components suppliers there, or at least somewhere in the EU?
            Might want to check:
            Farnell
            RS online
            TME.eu
            Maybe someone has a recommendation for a supplier that ships to Poland
            • Acnologia
              • Dec 2016
              • 429
              • Poland
              #46
              Farnell
              RS online
              TME.eu
              It's not about blaiming or not. I understand how you said it, but i cannot do anything else. Yeah , for future reference i will keep it in my mind .
              Yes, maybe he did something like that . Hypotheses most of the times are correct, i believe either plan a or plan b happened also , nothing else. But it's nice that someone else has the similar hypotheses as me hahah!
              Eitherway yea , they exist in europe but they charge too much for shipping a small package when aliexpress has it for 2$
              I found also a big book with capacitors just to have it on the side, so i bought also this and i am good, so another 3 weeks of waiting hahahahaha
              https://www.aliexpress.com/item/1005...503%21%211%210
              • m1ch43lzm
                • Mar 2019
                • 1064
                • Peru
                #47
                Get the 0201 and 0402 capacitor sample books, also the resistor books of those sizes
                For 0603 and 0805 caps, you don't know the voltage rating on those caps in the books, sometimes you need 10-22uF 25V 0603 or 0805 caps, very common to fail shorted on laptops, best to order those separately as the ones in the books may be rated at a lower voltage
                Can't beat free/cheap shipping from AliExpress... For me it's way more expensive to order from Digikey as they'd charge me 100$ flat fee shipping to Peru, on mouser it's 30$ shipping, not worth it for 1$ of caps
                • Acnologia
                  • Dec 2016
                  • 429
                  • Poland
                  #48
                  Yea ,bought both books as you said before you said it ,same mind
                  Also about 0603 and 0805 even though it's common i would prefer to get them separate when it's needed rather than going full speed ahead towards it now.
                  Oh , 100$? Sh*t.
                  For me it's 15$ even for 1 small package and the 'distance' is like next country border ...
                  I will try to check also Mouser, but i don't expect much.
                  • Acnologia
                    • Dec 2016
                    • 429
                    • Poland
                    #49
                    Just checked mouser.
                    30$ .
                    • Acnologia
                      • Dec 2016
                      • 429
                      • Poland
                      #50
                      Capacitors just arrived 1 minute ago.
                      Let's start changing and putting the ones missing and get back to you...
                      • Acnologia
                        • Dec 2016
                        • 429
                        • Poland
                        #51
                        Well hello there!!!! 👋
                        As soon as I attached from CG13 all the way to CG18.
                        WE HAVE PICTURE!!!!!
                        I will do some tests to make sure.
                        But come on!! 😀
                        Yessssss!!!
                        • m1ch43lzm
                          • Mar 2019
                          • 1064
                          • Peru
                          #52
                          Congrats!
                          It was a combination of the wrong LCD cable + the missing caps on the EDP data lines
                          Now fix the remaining caps marked in red in post 41, unfortunately due to forum issues/upgrade the pictures you uploaded were lost
                          Those are data lines that go to the thunderbolt retimer, the USB-C port attached to it won't work for data if those caps are missing, only for charging
                          • Acnologia
                            • Dec 2016
                            • 429
                            • Poland
                            #53
                            Congrats!
                            Already done, it charges all ,well diagnostic full . 100% without any issues.
                            We are good to go
                            You were amazing, and i gained knowledge .Thank you very much for your time ,effort and knowledge.
                            • Acnologia
                              • Dec 2016
                              • 429
                              • Poland
                              #54
                              Congrats!
                              It bounced back to me, and indeed it has an issue, even thought the diagnostic is 100% the full test of it, that takes hours.
                              Even though it recognises any SSD Nvme that i will put to it (bios) etc., when i try to install windows it says 'error with media' and shows that the disk is gone (any kind of disk , tested more than enough even brand new).
                              So i tested with Live-Ubuntu USB , and again the same issue ,boot from USB it starts booting, and then lags ,and no caps lock light ,or any mouse movement, you have to hard restart it.
                              But then again the diagnostics are fine...
                              • m1ch43lzm
                                • Mar 2019
                                • 1064
                                • Peru
                                #55
                                Does it boot Linux from USB if you remove the SSD?
                                Also try installing the SSD on another PC (unplug all other drives first), install Windows on the other PC then swap the SSD back to the E15
                                Google "sergei strelec", download the 2025.05.22 english version, and create a USB boot drive, it's bootable WinPE with useful diagnostic tools
                                Did you change your username?
                                • Acnologia
                                  • Dec 2016
                                  • 429
                                  • Poland
                                  #56
                                  Sorry for my late reply.
                                  Yes, i changed my username.
                                  Yes, i tried different ones and it worked . I am not sure why it behaved like that. All good so far. Thanks for the support once again
                                  • Coguar
                                    HP ProOne 23.8 inch G9 ALL-in-One Desktop PC - Working when plugged to an external monitor, no image otherwise
                                    by Coguar
                                    In the device manager there is no built-in display located. The Intel UHD Graphics are displayed and only the external display is visible. The AiO turns on and works but is only showing a black screen on the monitor.
                                    I checked the voltage on the backlight connector and it reads ~20V. I tried reseating the LVDS and Backlight connector, yet the image still does not show.
                                    Does anyone have ideas whether or not this is a BIOS related issue? The only visible log in the BIOS logs is that the firmware was updated around a month ago.
                                    We already tried to fix it by resetting the...
                                    06-23-2025, 07:14 AM
                                  • Madoy104
                                    Macbook Pro A1989 - No image, working fine with external monitor
                                    by Madoy104
                                    I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                                    08-15-2024, 10:01 AM
                                  • larrysito111
                                    dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                                    by larrysito111
                                    got here a liquid damaged alienware
                                    the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                                    so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                                    so with the usb-c external monitor is getting to bios and OS
                                    otherwise not
                                    so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                                    but still not the internal monitor
                                    (tested 3V and 5V going to the...
                                    06-12-2025, 04:16 PM
                                  • f-bone
                                    dell la-b843p image only on external
                                    by f-bone
                                    Hi guys,
                                    this one seems to work except that there is no image on LCD, only on external via HDMI. I have flashed the bios with a cleanME one and measured voltages at GPU (0.9V) and LVDS connector (LCDVDD_LCD is 19V and DCBATOUT_LCD is 3.3V). I can see the LCD going black after power on but no image. I shed some light with a torch but there is no image or activity at EDP_TX0/1 using the oscilloscope. I also tried a different panel.
                                    any ideas are welcome.
                                    br,
                                    george
                                    12-19-2022, 06:59 AM
                                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 02:20 PM
