HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
  • zaurus81
    • Feb 2021
    • 67
    • Italy
    Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
    WITHOUT BATTERY WITH BATTERY
    PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
    PIN2 (ACP)= 19.76 V PIN2 (ACP)= 19.76 V
    PIN3 (CMSRC)= 19.74 V PIN3 (CMSRC)= 19.74 V
    PIN4 (ACDRV)= 25.66 V PIN4 (ACDRV)= 25.66 V
    PIN5 (ACPRES)= 3.00 V PIN5 (ACPRES)= 3.00 V
    PIN6 (ACDET)= 2.68 V PIN6 (ACDET)= 2.68 V
    PIN7 (IOUT)= 0.00 V PIN7 (IOUT)= 0.00 V
    PIN8 (SDA)= 3.22 V PIN8 (SDA)= 3.09 V
    PIN9 (SCL)= 3.22 V PIN9 (SCL)= 3.09 V
    PIN10 (ILIM)= 0.99 V PIN10 (ILIM)= 0.99 V
    PIN11 (BATDRV)= 2.96 V PIN11 (BATDRV)= 1.07 V
    PIN12 (SRN)= 2.94 V PIN12 (SRN)= 1.05 V
    PIN13 (SRP)= 2.94 V PIN13 (SRP)= 1.05 V
    PIN14 (GND)= GND PIN14 (GND)= GND
    PIN15 (LODRV)= 0.00 V PIN15 (LODRV)= 0.00 V
    PIN16 (REGN)= 6.03 V PIN16 (REGN)= 6.03 V
    PIN17 (BTST)= 5.87 V PIN17 (BTST)= 5.87 V
    PIN18 (HIDRV)= 2.94 V PIN18 (HIDRV)= 1.05 V
    PIN19 (PHASE)= 2.94 V PIN19 (PHASE)= 1.05 V
    PIN20 (VCC)= 19.16 V PIN20 (VCC)= 19.16 V
    I removed the high and low mosfets to test them outside the circuit and they seem ok. analyzing the board with the thermal camera there are no hot spots, in fact even with the bench power supply the absorption with the board in standby (s5) is 7 mA.
    BQ gone??
    thanks in advance to anyone who answers me
  • mon2
    • Dec 2019
    • 14243
    CMSRC is between the 2 x DCin mosfets in the main power path. You should not have a voltage here when using only the battery. Confirm this measurement again.
    If you do, review the DCin mosfets for leakage.
    Remove all power. Meter in resistance mode.
    Measure:
    source / drain
    source / gate
    gate / drain
    Post each measurement. Test both DCin mosfets. Suspecting that at least the 2nd one is defective.
    Update - you have both, adapter & battery attached. Continue to test the mosfets as above.
    • zaurus81
      • Feb 2021
      • 67
      • Italy
      Measure:
      source / drain
      source / gate
      gate / drain
      hi mon2, sorry I expressed myself badly in a hurry, the values with the battery inserted were measured with the charging jack inserted, that's why I have 19.77 v
      DCin mosfets are PQ1015 PQ1003 PQ1002?? see boardview - https://www.badcaps.net/forum/troubl...75ambad0-rev-d
      • mon2
        • Dec 2019
        • 14243
        Yes, I agree with your findings.
        My search was as follows:
        (boardview file only)
        Searched for REGN -> found the charger IC -> found the ACDRV pin -> found the ACDRV series resistor -> other side of this resistor mates to the DCin mosfet gate pin # 4.
        • zaurus81
          • Feb 2021
          • 67
          • Italy
          DCin mosfets tested:
          first mosfet (PQ1003)
          source / drain 2.6M OHM
          source / gate OL
          gate / drain OL
          second mosfet (PQ1002)
          source / drain 4.3 M OHM
          source / gate 3,4 M OHM
          gate / drain 6,3 M OHM
          • mon2
            • Dec 2019
            • 14243
            Mosfets look ok to me. Suggest to test with another known good battery. Amazon?
            The low voltage with battery on SRN / SRP are of concern. These pins should reflect the battery charge voltage. That is, the high side and low side mosfets linked to the battery connector pins should be switching to dial up the ideal charge voltage to charge the pack. That is, unless the battery is locked.
            You can also test the nearby mosfets used by the battery in the same was as above to confirm they are not leaking.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              SRN/SRP voltage perhaps indicate a dead battery.
              • zaurus81
                • Feb 2021
                • 67
                • Italy
                good morning(evening) mon2, so from what you're telling me you're ruling out the presence of a damaged bq chip??
                • zaurus81
                  • Feb 2021
                  • 67
                  • Italy
                  hi mcplslg123, SRP/SRN without battery is 2.94V. is this normal due to no battery? or is the bq chip not switching the 2 mosfets?
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    maybe it can help you.
                    I'm not happy to be so strong. because it's not humanly
                    • Sephir0th
                      • Oct 2020
                      • 1282
                      Bad battery need to be ruled out.
                      FairRepair on YouTube
                      • zaurus81
                        • Feb 2021
                        • 67
                        • Italy
                        thank you
                        • maniche
                          • Jun 2020
                          • 37
                          • Kabylie
                          2,96 without battery look normal for me, but I don'tt see the voltage of battery, which mean the battery is dry, try to charge it with a power powersuplay ,if battery is to low the laptop will not charge it
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                            09-14-2023, 11:10 PM
                          • razenxd
                            How can I charge that battery pack?
                            by razenxd
                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                            Now, I have noticed a few things.
                            The "dead" battery, while connected to charger and NOT Charging will...
                            12-05-2024, 06:11 AM
                          • ruletero
                            Acer a515-43 low battery charge voltage
                            by ruletero
                            Hi
                            Acer A515-43
                            LA-H801P
                            Fail: Does not charge battery, has low voltaje on connector.
                            Laptop didn't want to turn on, only charge led blinked.
                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                            10-24-2022, 02:31 PM
                          • Klevjetack
                            Charge a L19D3PDA battery externally from the laptop
                            by Klevjetack
                            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                            03-05-2024, 07:26 AM
                          • dclass-pro
                            Latitude 3301 not charge battery
                            by dclass-pro
                            Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                            I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                            I noticed 2 things:
                            1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                            2) if I try to turn it on without the battery...
                            05-06-2025, 06:19 AM
