Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    Is this measurements ok?
    • mon2
      • Dec 2019
      • 14255
      What is the voltage to ground of SSD_PMU_RESET_L? If at 0v, continue to measure the following points of interest:
      (in order of the power up sequence chart - report any that are at 0v; continue otherwise to check each)
      P5V_3V3G3H_EN
      PP3V3_G3H_T
      P3V3MAIN_PGOOD
      P5VG3S_EN
      PP5V_G3S
      P5VG3S_PGOOD
      P1V8G3S_EN
      P3V3G3S_EN
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        SSD_PMU_RESET_L​ - 1,8V
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          P5V_3V3G3H_EN -0V
          PP3V3_G3H_T -3,3V
          P3V3MAIN_PGOOD - 0V
          P5VG3S_EN - 0V
          PP5V_G3S - 3,3V
          P5VG3S_PGOOD - 0V
          P1V8G3S_EN - 0V
          P3V3G3S_EN​ - 0V
          • mon2
            • Dec 2019
            • 14255
            Some of these measurements do not look correct. If you have a power rail then the _EN signals must be '1'. If you have the measured power rails then the _PGOOD should be '1'.
            Review the following to double-check each:
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              #26
              Hello, sorry for delay.
              PMU_PVDDMAIN_EN - 0V
              P5V_3V3G3H_EN - 0V
              P5VG3S_EN - 0V
              P3V3MAIN_PGOOD - 0V
              P5VG3S_PGOOD - 0V
              • martyjelen
                • Mar 2023
                • 127
                • Czech republic
                #27
                PP3v3_G3H_SOCPMU (measured on C7893/C7869) - 3.3V
                • mon2
                  • Dec 2019
                  • 14255
                  P5V_3V3G3H_EN -0V
                  Confirm the voltage to ground on each side of R7652.
                  Remove all power and confirm the resistance across R7652 which should be ~3k3 ohms.​
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    #29
                    0V on each side of R7652.
                    Resistance is about 3,2kΩ​
                    • mon2
                      • Dec 2019
                      • 14255
                      What is the voltage to ground of PPBUS_G3H @ F7000 / F7001? Is it stable?
                      • martyjelen
                        • Mar 2023
                        • 127
                        • Czech republic
                        #31
                        Both are exactly 12.3V/stable.
                        • martyjelen
                          • Mar 2023
                          • 127
                          • Czech republic
                          #32
                          I also checked voltage on R7900 (I read on forum that sometimes this resistor is the problem.) There is 3.3V on both sides.
                          • mon2
                            • Dec 2019
                            • 14255
                            Confirm the voltage to ground on:
                            R6968 ; CHGR_EN_MVR_R / CHGR_EN_MVR
                            R6934 / R6935 ; PP3V3_G3H_RTC_REG_R / PP3V3_G3H_RTC_X
                            • martyjelen
                              • Mar 2023
                              • 127
                              • Czech republic
                              #34
                              R6968 - 5.1V on both sides.
                              R6934 / R6935 - 3.3V on both sides.
                              • mon2
                                • Dec 2019
                                • 14255
                                Good. Onto steps 6 & 7.
                                • martyjelen
                                  • Mar 2023
                                  • 127
                                  • Czech republic
                                  #36
                                  PP3V0_G3H_RTC - 3V
                                  PCH_CLK32K_RTCX1 - 0.5V
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    #37
                                    Should I continue with next measurements?
                                    • mon2
                                      • Dec 2019
                                      • 14255
                                      Yes.
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        #39
                                        Step 8 - PCH_RTC_RESET_L - 3V
                                        Step 9 - PMU_XTAL1 - 0V / PMU_XTAL2 - 0.6V
                                        Step10 - PP3V3_G3H_T - 3.3V
                                        Step 11 - PP1V8_SLPS2R - 1.8V
                                        Step 12 - PMU_CLK32K_SOC - 0.8V
                                        Step 13 - PP1V8_AWAKE - 1.8V
                                        Step 14 - PP1V8_SLPS2R_PMUVDDGPIO - 1.8V
                                        Step 15 - PP1V1_SLPS2R - 1.1V
                                        Step 16 - PP0V8_SLPS2R - 0.8V
                                        Step 17 - PP0V82_SLPDDR - 0.8V
                                        Step 18 - PP3V3 _AWAKE - 3.3V
                                        Step 19 - PPVDDCPUSRAM_AWAKE - 0.8V
                                        Step 20 - PP0V9_SLPDDR - 0.9V
                                        Step 21 - P1V1_SLPDDR_SOCFET_EN - 1.8V! (is it OK?)
                                        • mon2
                                          • Dec 2019
                                          • 14255
                                          Step21 - this is the enable pin for the loadswitch @ U7901. The enable voltage can be different than the operating voltage of the switch.
                                          Confirm the voltage to ground on U7901, pins #3 and #5. Are they stable @ 1v1 for each? Then this is ok.
                                          • platinumsteel
                                            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                            by platinumsteel
                                            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                            03-18-2024, 05:16 PM
                                            Apple MacBook Pro A2141 X970 820-01700 Schematic & Board View
                                            Apple MacBook Pro A2141 X970 820-01700 Schematic & Board View...
                                            10-02-2024, 02:57 PM
                                          • mferna14
                                            MacBook Air A2179 stuck on Apple Logo
                                            by mferna14
                                            Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                                            04-06-2023, 03:45 PM
                                          • sdogs
                                            Macbook Pro 15 A2141 820-01700-A stuck at 5V
                                            by sdogs
                                            Happy Sunday everyone,
                                            I have this Macbook Pro 15 A2141 820-01700-A stuck at 5V, it doesn't have any liquid marks or burn marks, I have carefully inspected the logic with the microscope and have not found any anomalies.
                                            By connecting the usb-c tester I could see that it is blocked at 5v, and as a first measurement I checked PPBUS_G3H which has a voltage value of 0.8v and measured in 0.06 ohm diode mode.
                                            I read a bit in the forum and I tried to inject 1v on the F7000 not having any current absorption, I then went up to 1.5v and I had a light current absorption (0.10Amp) and...
                                            09-03-2023, 09:52 AM
                                          • oxonater
                                            Apple MacBook Pro A2141 16" IC BYPASS
                                            by oxonater
                                            Hi everyone hope all are well
                                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                                            I suppose it's worth noting googling the part package brings up various...
                                            10-23-2024, 11:21 PM
