Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
  • mon2
    • 14672
    Plan B is to manually remove and reflash the T2 rom with the firmware for this logic board. The ROM devices are funky shapes so you will need a special PCB or socket to reflash this device.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      #62
      I found this, but I don't know how to make it work. I'll check Google.
      • mon2
        • 14672
        We have similar but not the same socket. This is a SMD to PDIP zero force socket. Once you seat with pin #1 on the SMD to the pin #1 on the programmer, you will be able to R/W/E the target flash rom. I believe in the ROM sub-forum, you will be able to find the T2 rom dump for your machine. If stuck, ping me and will hunt around for the same. According to Master Liu (Shenzhen), he noted that the T2 dumps are not serialized so you should be ok to use a T2 dump from a known good machine. I have been kicking the repair of a high end imac and need to do the same as you. Perhaps will attempt it tomorrow. Be sure to backup the original (twice) to be safe before erasing and reflashing. After you do this, Master Liu noted that the machine will be in DFU mode. Then attempt again to see if the logic board is detected by the configurator DFU tool.
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          #64
          Unfortunately, this cannot be used with BeeProg that I have. One question before I'll look for other programmer. After you rewrite T2 ROM dump is there "revive" option? Or only "restore" option. I mean data is really important.
          • mon2
            • 14672
            Not sure. You will have to attempt the repair to find out. Post your updates.
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              #66
              Hello, finnaly I found a way to read T2 ROM dump. ROM from my dead PCB has 16MB but when I downloaded a ROM from forum it has only 4MB... Could you tell me what could be wrong? This dump also has the same size 4MB
              https://boards.rossmanngroup.com/thr...o-power.63469/
              • mon2
                • 14672
                Let me check some alternate sources once at the office.
                • martyjelen
                  • Mar 2023
                  • 127
                  • Czech republic
                  #68
                  Ok. Thank you very much. Maybe there is some difference between 820-01700-05 and 820-01700-A (mine PCB).
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    #69
                    I tried to rewrite ROM, but it's still the same. No DFU.
                    • mon2
                      • 14672
                      What is the voltage to ground of PPBUS_G3H​ now?
                      • martyjelen
                        • Mar 2023
                        • 127
                        • Czech republic
                        #71
                        PPBUS_G3H​ is 12.3V on top left port. On bottom port there is 0V. (it goess from 5V to zero after 2 seconds.) Could it be problem with CD3217?
                        • mon2
                          • 14672
                          Yes, each and every cd321x port must be working to proceed. Test each LDO rail on the non-working cd3217. Inspect for liquid damage. Connector ok or contaminated with maple syrup?
                          • martyjelen
                            • Mar 2023
                            • 127
                            • Czech republic
                            #73
                            There was no signs of liquid damage on connector or nearest area, but when I removed CD3217 (U3100), there is corrosion. OMG.... Wish me luck.
                            • martyjelen
                              • Mar 2023
                              • 127
                              • Czech republic
                              #74
                              Does this mean A2141 is compatible only with A2159? https://repair.wiki/w/CD3217_compatibility or am I wrong? Thank you.
                              • mon2
                                • 14672
                                According to the landing page, yes. The controller is compatible on the listed 2 models. Personally suggest to stick with a controller removed from a known good A2141 and from the same location as the part you wish to replace. You may want to chat with vendors on Aliexpress who sell these devices but purchase from a reputable vendor. Even better if you can perform the surgery using a donor board - at least for this initial repair. Remove -> reball -> replace.
                                • platinumsteel
                                  Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                  by platinumsteel
                                  Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                  03-18-2024, 05:16 PM
                                  Apple MacBook Pro A2141 X970 820-01700 Schematic & Board View
                                  Apple MacBook Pro A2141 X970 820-01700 Schematic & Board View...
                                  10-02-2024, 02:57 PM
                                • ApplePie14
                                  MacBook Pro 2019 16inch A2141 no power
                                  by ApplePie14
                                  My Macbook, which had been working fine until two weeks ago, now has unstable power and won't turn on.
                                  When I took it apart, I found a lot of dust, so I think that might be what caused the damage.
                                  I checked with a USB meter and found that the voltage is 20V, and the current consumes a maximum of about 150mA, then fluctuates between 4 and 70mA.
                                  The same thing happens when the battery is removed.
                                  There were no short circuits in the PPBUS_G3H or NAND.
                                  08-25-2025, 12:17 AM
                                • mferna14
                                  MacBook Air A2179 stuck on Apple Logo
                                  by mferna14
                                  Hi all, working on a MacBook Air A2179 EMC 3302 stuck on Apple Logo. Came in dead. There was spillage on both of the USB-C Charge port connector. I replaced the cap 4.7UF 25V near the speaker connector as it was corroded. Replaced USB-C connector with a new one & now I get display. The problem is that gets stuck on the Apple logo & sometimes it even boots up into OS after a very long time & the CPU fan spins fast. Kindly any repair tips will be appreciated. Do these logic board have BIOS, so that I could do a clean up or load a new dump. Thanks in advance.
                                  04-06-2023, 03:45 PM
                                • sdogs
                                  Macbook Pro 15 A2141 820-01700-A stuck at 5V
                                  by sdogs
                                  Happy Sunday everyone,
                                  I have this Macbook Pro 15 A2141 820-01700-A stuck at 5V, it doesn't have any liquid marks or burn marks, I have carefully inspected the logic with the microscope and have not found any anomalies.
                                  By connecting the usb-c tester I could see that it is blocked at 5v, and as a first measurement I checked PPBUS_G3H which has a voltage value of 0.8v and measured in 0.06 ohm diode mode.
                                  I read a bit in the forum and I tried to inject 1v on the F7000 not having any current absorption, I then went up to 1.5v and I had a light current absorption (0.10Amp) and...
                                  09-03-2023, 09:52 AM
