MacBook A2141 one USB port dead and one power cycling
  • dbuergi
    • Jul 2024
    • 135
    • Deutschland
    I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
    Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw.
  • mon2
    • Dec 2019
    • 14671
    See attached. You are at the power sequence #1 stage.
    Remove all power. What is the resistance to ground of PPDCIN_G3H? Issue is most likely with one or more of the CD3217 PD controllers.
    • dbuergi
      • Jul 2024
      • 135
      • Deutschland
      Resistance to ground is 955 Ohm.
      • mon2
        • Dec 2019
        • 14671
        This may be your case study:
        https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
        • dbuergi
          • Jul 2024
          • 135
          • Deutschland
          I replaced one cap and gave both CD3217 on the right side a reflow. Now all ports show 5V and 0,17A. Also no difference with battery connected so next step should be to try a DFU restore?
          • dbuergi
            • Jul 2024
            • 135
            • Deutschland
            Sorry was not able to edit but i made a mistake. 3 Ports Show 5V and 0,2A and one 5V and 0,12A.
            With battery connected three ports show 20V and the one stays at 5V and 0,12A. So still problems with the Cd3217 of this port?
            • mon2
              • Dec 2019
              • 14671
              Use the port that allows for 20v for now. What is the volt to ground on PPBUS_G3H?
              • dbuergi
                • Jul 2024
                • 135
                • Deutschland
                12,3v and cycling to 11,6v and going back to 12,3 again.
                • mon2
                  • Dec 2019
                  • 14671
                  Test the nand flash capacitor to see if it is shorted.
                  reference:
                  https://repair.wiki/w/MacBook_Pro_A2..._at_20V_repair
                  No power to the board when testing the resistance to ground.
                  • dbuergi
                    • Jul 2024
                    • 135
                    • Deutschland
                    reference:
                    Sorry was busy the last days. Cap and everything around is fine and somehow my 5v port is now dead again and all others show 5v.
                    The one marked with X isn't showing anything right now. I added values i got when connecting power to the other port.
                    Can this all be the problem of a faulty UB300 or do i have to look anywhere else?
                    • dbuergi
                      • Jul 2024
                      • 135
                      • Deutschland
                      I reballed UB300 to see if it changes anything and all values look fine besides CB308 being at 30 Ohm.
                      But testing was not possible. Port for UB300 still shows nothing with USB tester connected (dead) and port for UB400 just flashes for a second and turns of and on again in a loop. Never had the situation where the port was "dead" so any ideas what to check or can this also be the case when UB300 needs to be replaced?
                      • dbuergi
                        • Jul 2024
                        • 135
                        • Deutschland
                        So, i got a donor board and changed UB300. All ports work now but i only get 5,17V, 0,06A and 0,33W.
                        The port flashing was a faulty ISL9240 which i also replaced.
                        • mon2
                          • Dec 2019
                          • 14671
                          Test the voltage to ground of each LDO rail on the CD3217. Confirm the voltage on each pin of the SPI flash used by these PD controllers.
                          • dbuergi
                            • Jul 2024
                            • 135
                            • Deutschland
                            CB304 1,5V
                            CB300 3,4V
                            I took SPI flash out and got 0,90V on pin 5+6 and every other pin 3,3V besides pin 4 GND 0V. With SPI flash back on board i got 0,40v on 5+6 and all others showed 0V.
                            Also i took the ISL9240 out again since the pads looked strange under the microscope.
                            • mon2
                              • Dec 2019
                              • 14671
                              Meter in DIODE mode. Measure each pin on the flash device in diode mode. Red meter probe to ground. Black meter probe to the pin to test. It appears from your last post that this flash device is defective. Post each measurement.
                              • dbuergi
                                • Jul 2024
                                • 135
                                • Deutschland
                                Hello mon2,
                                Since nobody is sure if both CD3217 chips need to be changed i also changed the second and SPI flash chip from donor. Now i have:
                                P1 0,6V
                                P2 0,6V
                                P3 0,6V
                                P4 0V
                                P5 0,6V
                                P6 0,7V
                                P7 0,7V
                                P8 0,5V
                                Right now i saw that the ISL9240 has two strange looking pads under the microscope. I will also reball it again. Somehow the chip sucks off all head and it takes ages to solder it. Newer had this problem before. Maybe i should use a heating plate.
                                • mon2
                                  • Dec 2019
                                  • 14671
                                  These are good diode mode measurements. Nothing appears to be shorted here. If you power up with this new flash device, what are the voltages to ground on each flash pin? Appears to be a better device than the original.
                                  • dbuergi
                                    • Jul 2024
                                    • 135
                                    • Deutschland
                                    I get power cycling from 0,3V to 3,4v and USB tester ist flashing. This happends with soldered ISL9240 chip.
                                    Checked everything again and i have a short to ground at C7080, so search goes on.
                                    • mon2
                                      • Dec 2019
                                      • 14671
                                      ISL soldering is good? What is the resistance to ground of C7080?
                                      • dbuergi
                                        • Jul 2024
                                        • 135
                                        • Deutschland
                                        I reballed it two times and it moved in position.
                                        C7080 shows 3,4 Ohm. Meassurements also stay this low with ISL and / or C7080 removed.
                                        Also with the changed CD3217 removed again the line stays low. I tried some voltage injection and got 30C hot spots at T2 chip and U7800. Is there a chance that they cause this problem even 30C is not really concerning.
                                        • tomtom67
                                          MacBook Pro 16" (2019) A2141: power consumption? Dead GPU? MacOS not installing
                                          by tomtom67
                                          A friend brought his fresh-from-ebay macbook pro A2141 after he failed replacement keyboard plugging.
                                          I fixed all the little problems he introduced.
                                          I am unable to install macOS to this device. Both Sequoia and Catalina (from Internet Recovery) start to install, but after ~2-5 minutes into the installation the macbook does a hard restart (max fan spin for a split second, then reboot without chime).
                                          I noticed what I think is a very high power consumption, like 20V/1.7A when activating WiFi for internet recovery, and more like 20V/3.7-4.1A while downloading the recovery...
                                          10-08-2024, 08:59 AM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • usbdevice
                                          Acer X223HQ (Version Bbd) on/off-power-cycling
                                          by usbdevice
                                          Hi all
                                          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                                          https://www.badcaps.net/forum/showthread.php?t=50657
                                          https://www.badcaps.net/forum/showthread.php?t=40512
                                          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                                          It's my dad's old monitor. He...
                                          08-05-2022, 02:21 AM
                                        • mon2
                                          A2141 820-01700 Power cycling (DFU worked ok)
                                          by mon2
                                          Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
                                          Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board...
                                          11-24-2023, 12:17 PM
