A2141 820-01700 Power cycling (DFU worked ok)
  • mon2
    • 14770
    Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
    Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board which will nuke the client's data. Perhaps the NAND flash is corrupted and causing this power cycling? The display is defective from user's CAM privacy shutter crushing the panel.
    Q: Could this be a corrupt bios fault?
    Tested SMBUS / I2C lines are not shorted.
    Currently in chat with Master Liu (Shenzhen) who is able to extract the required client'd data if the T2 and NAND flash devices are not defective. We know that the T2 chip is ok since PPBUS_G3H is @ 12v6 (normal voltage). Cannot comment on the condition of the NAND flash but they are not heating up nor with a super low resistance on their power rail -> their power rails at a normal voltage to ground.
    Welcome all comments before sending in for repair to Master Liu whom we suspect will remove the T2 + NAND FLASH off this logic board and transplant onto a working donor board. Not a fun process.
  • anhbanxoi
    • Sep 2021
    • 180
    • VN
    If you can revive the device in DFU mode mean SSD is ok and 12.6V in PPBUS also indicate good T2. You could try to reflow the RAM chips or try holding T when press the power button to boot it into target disk mode and copy data from there.
    • mon2
      • 14770
      @anhbanxoi, thanks so much for your advice. It worked!! The client was very nervous about sending off the logic board to China although we have faith in Master Liu so we kept testing.
      Your suggestion worked and the details are as follows:
      1) LCD was damaged so that did not help.
      2) We removed the trackpad during the logic board removal process to validate if the battery pack was a fault. New battery pack behaved the same. The missing trackpad caused the fan to spin into very high speed and forced a repeated power down after a few seconds. This further complicated the process. The thermal camera did not show us any faults as most of the temps were under 50 degrees before the forced shut down of the logic board.
      3) We re-connected the trackpad and the fan spin returned to normal.
      4) Sourced a 40G rated USB cable for the 'target mode' procedure using our A1534 host system. After a few attempts of powering up while the 'T' key was pressed -> we saw the logon screen on the A1534 remote unit. The password failed to open the system but we selected 'hint' and the correct hint was displayed. This gave us further hope that the nand flash is not corrupted.
      5) Due to the urgency, we purchased a known good and working A2141 with Sonoma OS pre-loaded.
      6) This combination worked perfectly with the same setup and a drive letter appears -> performed the MIGRATION to effectively clone the non-working defective A2141. Client was super pleased as the data was extremely valuable to continue to run their business.
      Take away - learned that this 'T' mode is an early stage bootloader that is very helpful for such cases. Local Apple store could not perform this task? They wanted to send away the unit which the client refused.
      If PPBUS_G3H = 12v6 = T2 is ok and has booted.
      Thanks again @anhbanxoi - very much appreciated and hope this thread helps others.
      • hazar
        • Aug 2016
        • germany
        l have same problem fan spin max no image and no chime restore with dfu done but same
        PPBUS_G3H = 12v6 = T2 is ok​
        • mon2
          • 14770
          If you have a high fan spin, then there is a fault with the trackpad or trackpad cabling. There are sensors inside of the trackpad that must be present and only then the logic board will slow down the fan spins to a normal rate. For our case, we needed to salvage the data off the original machine for a very large local customer. Other shops, including Apple, stated it was not possible to save.
          • tech_guru
            Macbook Pro 2019 A2141 NAND Shorted
            by tech_guru
            Hello. If you could please help me understand what I am doing wrong...
            This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
            I also replaced the tps power ic for the ssd.
            Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
            08-28-2025, 08:04 AM
          • cheebster
            MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
            by cheebster
            Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
            Nand voltages are missing.
            I've found no shorts at all so far, no signs of heat via thermal camera either.
            PPBUS_G3H 12.31
            PP3V3_G3H_RTC 3.387v
            PP3V3_G3H 12.31v
            PP2v5_NAND_SSD0 0v 58 ohms
            PP2v5_NAND_SSD1 0v 57.8 ohms
            PP1v8_SLPS2R 1.8v
            PP1v1_SLPS2R 1.1v
            P3V3_G3H_SOCPMU 3.37v
            PP0V9_SLPDDR 0.9v...
            10-11-2023, 11:31 AM
          • dbuergi
            MacBook A2141 one USB port dead and one power cycling
            by dbuergi
            I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
            Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
            04-25-2025, 11:40 AM
          • tranquility
            Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
            by tranquility
            i want to repair an Onkyo TX-NR809 receiver.
            symptoms:
            on power on, display appears and i hear one click. enue functions is given.
            - no hdmi output
            - audio output not tested, but i think it is not there
            - usb sticks are not recognized
            if i read out the chips with display+standby button + tone+
            both dts show only ????
            chip is D830K013BZKB4
            things i have done:
            - reflow of the dts chip without taking off and reballing
            - changed the aluminium caps without the big one with 25v because i dont...
            08-25-2025, 01:04 AM
          • high-tech
            Samsung UN55F7050AFXZA ver. TD01 power cycling
            by high-tech
            Hello everybody, I could use some help on this one... It's got me guessing...
            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
            9. ground (PWM2) 10. 0.9 volts cycling...
            09-15-2020, 03:39 PM
