GDM50 LA-L241P Rev 1.0 - 2 Amber and 7 White Led Fix Needed
  • m041633n
    • Oct 2020
    • 21
    • india
    Hello Everyone!
    I would like to know the Jumper location for the 2 Amber 7 White Led Blink Code error. According to Dell 2,7 Led codes are for display or the Display cable failure. I didn't changed the display nor the cable. The issue happens only when restarting the machine from windows and from the BIOS. And when opening and closing the lid the display turns off and never turns back on. But the machine is working! I confirmed it by pressing the CAPS Lock key. Does anybody has this issue and fixed it by jumpering some fet near the display connector on the motherboard. If So Please Help me. And other help is also much appreciated
    Note: I tried cleaning the display Cable connectors on both the display end and the motherboard end. Tried squeaking the cable nothing worked. Please help BTW My laptop Model is Dell Inspiron 15 3511
    Thank you!Click image for larger version
  • m041633n
    • Oct 2020
    • 21
    • india
    Please somebody help me!
    • mon2
      • Dec 2019
      • 14726
      See if this thread helps:
      https://www.dell.com/community/en/co...ccf8a8deea7b98
      • m041633n
        • Oct 2020
        • 21
        • india
        Tried it Mr.Mon2
        • m041633n
          • Oct 2020
          • 21
          • india
          Well I replaced the display. The Problem Solved 😕 😪
          • Themi
            Dell XPS 13 9310 2 amber 4 white memory failure
            by Themi
            I have this laptop a dell XPS 13 9310
            Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
            I believe this is the spec from using micron tool to decode marking
            Images of the ram
            I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
            Another...
            11-24-2024, 09:06 AM
          • s_henya
            Dell Inspiron 3593 3 amber 1 white
            by s_henya
            Got this in today,
            no signs of life.
            found a broken charging port- after replacing it, the laptop turns on and charges the battery.
            Trying to turn it on, laptop powers up, capslock is on and not responding, no image on the screen. Indicator led is flashing with 3 amber 1 white.
            CPU and GPU are very hot, so laptop has all the required voltages.
            Cmos battery is okay ~2.9v which supposed to be okay.
            Could it be a bios problem?...
            10-14-2024, 03:10 AM
          • stevenallauca
            HP laptop does not charge the battery, the light turns amber and then changes to white.
            by stevenallauca
            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
            - ACN (BQACN) 19.6v
            - ACP (BQACP) 19.6v
            - CMSRC (BQCMSRC) 19.6v
            - ACDRV...
            09-23-2024, 11:30 AM
          • Amirnsrti
            Dell Inspiron 5567 2 amber 6 white error
            by Amirnsrti
            Hi everyone
            I have this Dell Inspiron 5567 laptop that shows 2 amber 6 white error when I try to turn it on it's fan starts to work at very high speed even though I just turned it on and laptop is cold, screen is black but it shows very dim lines for less than a second when I click on power button. I used it like 4 years and I got this error so I didn't used it for last 3 years.
            The error it gives is for motherboard chipset issue.
            I Read some topics that something is wrong with bios but I don't really know how to flash the bios using another bios file. So I really appreciate...
            07-08-2024, 10:40 PM
            MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
            This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-06-2024, 07:46 AM
