HP DM4 help needed.
  • cdicky
    • Jul 2014
    • 27
    • England
    HP DM4 help needed.
    Hi all, 1st post.
    Sorry to come here to ask but really stuck. Not too hot with laptop repairs.
    Although this seems a common problem fo HP.
    Basically HP DM4 that had slight corrosion / condensation problem on motherboard. Its all cleaned (about three caps ) and checked for shorts .
    Now whether related or not, I assume it must be, board is dead. No lights power or anything. Charging socket has built in led. Also has several wires (some just doubled up) to a board socket, but one is apparently a 'data' return line to charger. Power good circuit?
    The charger and battery both been tried in another machine and appear normal.
    There is one small chip I cant identify near the power socket thats getting very warm, but other than no power / volts anywhere.
    Does anyone have any info, like schematic or experience with these or or similar?
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Re: HP DM4 help needed.
    post good quality image. post motherboard code for others to know.
    • cdicky
      • Jul 2014
      • 27
      • England
      Good idea- thanks
      Not sure if this will work by linking.
      http://picasaweb.google.com/11584027...eat=directlink
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        If you had corrosion, shorted ceramic caps are common. Start from the input jack downwards.
        A working TV? How boring!
        • techman1025
          • Jun 2014
          • 497
          Hi
          When you plug in dcjack is the led for jack lit? No ?? if no and power adapter is good and also dcjack and have the 19V coming in then i would start with bios firmware known problem (if you give me full model i would upload a new clean dump... if dcjack is lit then move on to alwson voltage 3/5 ..with adapter plugged in and don't press power button just check all the big square coils until you find the 3/5 they will be side by side and all the rest coil want have voltage until power button is pressed. let me know
          Techman1025
          • cdicky
            • Jul 2014
            • 27
            • England
            Pretty certain NOT bios or any other software problem.
            Because it is not getting any power. The charger works in another machine but not this one.
            Ive been told and evidensed by the jack socket, that there is a data pin to the charger. Basically the logic circuits disable the charger (or prevent it switching on) there by limiting any power to the board. I've poked around with a meter but volts just flicker around the half volt mark.
            I cant see / dont know the circuit that controls this. Maybe its not but maybe a fauly shorted or open transistor. Trouble is there are many different types with different values.
            • cdicky
              • Jul 2014
              • 27
              • England
              Just a little update / progress report.
              Identified 2 transistors that pretty sure have one leg short circuit.
              They are 12w 13 or here BSR13R SMD Transistor http://www.ebay.co.uk/itm/BSR13R-SMD...-/160937411559
              Bit pricey though.
              And unfortunatly there is still a def short. (after removing them)
              I also re-cleaned and dried the board making sure no memnants of any crap remained.
              one bit of shock as the penny dropped. After removing all the plastic + shrouds realised the cpu + gpu are glued to the board.
              So if a new replacement is found cheap enough, its got to include these as well aaagh
              https://www.badcaps.net/forum/images...es/lolsign.gif
              • techman1025
                • Jun 2014
                • 497
                Hi
                The center pin is the data pin so this is how the laptop knows adapter type watts and so on this will ONLY prevent it from charging it will not prevent it from power on ..a warning will appear telling you to type F1 to continue . so it will power up and run it just want charge if it's the wrong adapter meaning watts rating or type even if center pin is broken same out come.
                Techman1025
                • techman1025
                  • Jun 2014
                  • 497
                  Hi
                  Techman1025
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                  • flat-earther
                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                    by flat-earther
                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                    Windows also shows ''Plugged in'' when charger is not connected.
                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                    If I let battery run out and say it has 3% Windows will...
                    06-24-2025, 09:32 AM
                  • Johndill
                    Dell Inspiron 7567 LA-D993P odd charger issue
                    by Johndill
                    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                    Here are the tested scenarios:
                    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                    2. With the laptop off, plug in charger (LED says on) & the front charging...
                    11-16-2022, 10:55 PM
                    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                    Narrow VDC applications where the system power source is
                    either the battery pack or the regulated output of the charger.
                    This makes the max voltage to the system equal to the max
                    battery voltage instead of the max adapter voltage. Operating
                    at lower system voltage can improve...
                    11-05-2024, 04:43 PM
