ASUS X756UV BIOS Bricked?
  • kraZZeman
    • May 2024
    • 8
    • Poland
    Hello, I have a problem with starting my laptop. I got a laptop that doesn't start. It turned out that it was flooded with liquid. I removed the corrosion, replaced the damaged elements and the laptop started. Before I understood what the problem was, I uploaded a new BIOS with a clean ME region downloaded from this forum. The laptop started and worked. However, I decided to upload the original BIOS back. I cleared the ME REGION in it and uploaded it to the chip. After this procedure, the laptop stopped starting. It uses 6 watts constantly without any changes. Also, uploading back the BIOS with which it started after repair doesn't help. Is it possible the KBC chip is bricked? I don't have a programmer for KBC systems. Do you have any ideas? Thanks!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    KBC firmware is unlikely to be corrupt. Check whether chip is properly soldered and do check for any missing resistors nearby.
    • kraZZeman
      • May 2024
      • 8
      • Poland
      I have checked this before. Everything with resistors and capasitors is fine. Like I said before flashing it was working properly. So i need to find a way to flash KBC it seems...
      • mon2
        • 14206
        Is the EC rom internal or external on this board? My database shows a dump for this model which I can post if needed.
          • 20914
          Post the original bios backup in the bios requests forum - https://www.badcaps.net/forum/troubl...-requests-only ,and post the laptop serial number (type it please) ,and also post a picture of the barcode sticker on the ram slot
          • kraZZeman
            • May 2024
            • 8
            • Poland
            Thank you, I just did it.
            • kraZZeman
              • May 2024
              • 8
              • Poland
              I'm sorry, but because I don't have any programmer for KBC I don''t have enough knowledge about what it means internal or external ROM.
              • mon2
                • 14206
                Wait on others to comment but from this video, the EC ROM chip is an external part. That is, the EC controller = KB9026Q is the controller and it uses the external Winbond chip to hold the firmware (program). If indeed, this external flash device is corrupted, then a known good EC rom dump should be suitable to apply onto this target flash chip.
                https://www.youtube.com/watch?v=CgDV2oxQhsI
                This YT video is using the u-Link NT Programming tool and from a quick Aliexpress search, someone is attempting to gouge the buyer @ $3k for this device worth about $5. Suspecting there are many options to reflash this target memory device including the option to remove this flash chip -> program with the device with a low cost tool and then solder it back.
                Confirm if you have this flash device on your board like showing in the video when he flips the board over.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Once again i'm saying its not EC bios. EC has a separate flash chip and the ec bios is not pulled from main bios in this case.
                  Since you only flashed main bios, it has nothing to do with ec bios.
                  Rather, look carefully at liquid spill area and you may get a clue.
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • studdy05
                    Bricked HP Probook 450 G7 Bios questions
                    by studdy05
                    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                    Ive got...
                    07-08-2025, 09:24 PM
