Acer Spin 3 SP314-54N, Mainboard Lenny_ICL 19771-1 no power,
  • master3112
    • Mar 2024
    • 89
    • Slovakia
    Hello everyone.
    I have an Acer Spin 3 SP314-54N, mainboard: Lenny_ICL 19771-1.
    The device does not start. I have 19V at the input of the PU4408 (AON21321). Gate voltage is also 19V but the MOSFET is not opened. I have also replaced the MOSFET and it is OK. The gate voltage is provided by two resistors PR4418 (200k) and PR4419 (100k). I unsoldered both and measured them, all okay.I also desoldered and measured the PC4453, which is OK. I desoldered the PU4408 and short-circuited pads 1-3 with pads 5-8. Then the device started normally. Does anyone know what gate voltage the PU4408 should have? Maybe it is too high and therefore the PU4408 does not open?
    The second MOSFET (PU4401) in the 19V rail is also an AON2132 and I have swapped the two with each other but still no change. When I short-circuited the PU4408, the PU4401 had a gate voltage of only 17V. Should the PU4408 also have a gate voltage of 17V?
    Does anyone have any ideas and can help me?
    Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: image.png Ansichten: 0 Gr??e: 164,8 KB ID: 3569291​​
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    It is a P-channel, so yes, it needs a lower voltage on gate to conduct.
    • pc_okay
      • May 2022
      • 244
      • FRANCE
      Yes, acer reinvent the wheel again using P-Channel mofset.
      Check resistance to ground on:
      PR4404
      Check carrefuly voltage:
      AC_DET / DC_IN_OK (3.33V) and PWR_CHG_ACDET (to check if the charger is properly detected)
      PWR_CHG_VCC (19V ~) (to check if your IC charge is powered)
      PWR_CHG_ACOK (3V ~) to check if your charging system is good to go)
      PWR_CHG_REGN (to check if your IC charge is working fine)
      PWR_CHG_ACN
      PWR_CHG_ACP
      report your results please. 😀
      • master3112
        • Mar 2024
        • 89
        • Slovakia
        Thank you for your support pc_okay.
        I have remeasured the values on the PU4403:
        Resistance at PR4404 270k
        AC_DET / DC_IN_OK (3.33V) I have only 1.3V, I have unsoldered and measured the resistors R4301 and R4302 and they are OK.
        PWR_CHG_VCC (19V ~) = 19V
        PWR_CHG_ACOK (3V ~) = 0V
        PWR_CHG_REGN = 0V
        PWR_CHG_ACN = 0.2V
        PWR_CHG_ACP = 0.2V
        I have also replaced the PU4403 power controller, no change.
        • mon2
          • Dec 2019
          • 14803
          The dual diode @ PD4403 is a suspect. This dual diode feeds into the AC_DET pin. Measure the voltage to ground on each leg of this dual diode and share the measurements.
          • master3112
            • Mar 2024
            • 89
            • Slovakia
            The TWIN diodes PD4403, PD4406, PD4409, PD4411 check whether input voltage is present either via DC socket or USB-C. At one of the inputs of the twin diode, 19V is checked via DC socket 19V_AD_JK and at the other 20V via USB-C 20V_TYPEC1_VBUS20 depending on the operation via USB-C or mains adapter.
            In mains operation is 19V (19V_AD_JK) present at PD4406, PD4411.
            In mains operation isnt19V (PWR_ADP_19V )present at PD4403 and PD3310, which is also understandable because PWR_ADP_19V is only tapped after PU4408 and this does not open.
            With USB-C operation is 20V (20V_TYPEC1_VBUS20) available at PD4403, PD4406, PD4409, PD4411.
            I have tested operation via USB-C. The device does not start via USB-C either. I have also desoldered and measured PD4403, PD4406, PD4409, PD4411 and these are OK.
            The PU4408 is switched by PQ4402. 19V_AD_JK is present at PIN1 of the PQ4402. At PIN3 of the PQ4402 PWR_ADJK_G there is also 19V which is too much as rogfanther ​writes. The PQ4402 therefore appears to be open. PQ4402 opens when ground is present at PIN2. When PQ4402 is open, it switches 19V_AD_JK through to the gate of the PU4408 and the PU4408 remains closed. I removed the PQ4402 and had 6V at the gate of the PU4408. The PU4408 was open and the device came on. The PQ4402 therefore appears to be continuously open. PQ4402 is switched by PQ4401 and also via the PD4410 twin diode. PQ4401 is switched by EC U4401. (This Circuit is OK.)
            ​I checked the area of the PD4410 twin diode. I desoldered the PD4410 twin diode and the device started. The gate of the PQ4402 is therefore switched to ground via the PD4410 twin diode. The PD4401 diode can therefore only switch the ground via PQ4405. I reinstalled the diode and desoldered the PQ4405. I have 19V at PIN3 of the PD4410 diode. The device starts via power supply and also via USB-C. This means that the PD4401 is also OK. I have 9V from PD4411 at PIN5 of the PQ4405. So the PWR_CHG_ADPID# signal also seems to be OK, or should there be a different voltage there? Nevertheless, I have ground at PIN3 of the PQ4405. At this point I don't know when and why I have ground at PIN3 of the PQ4405. I have unsoldered PQ4405 and measured PIN4 against PIN3 and have a resistance of 4.7M.
            So the problem seems to be only in the control of the PU4408. The PU4408 circuit is actually only switched through this area.
            Klicke auf die Grafik f?r eine vergr??erte Ansicht  Name: image.png Ansichten: 0 Gr??e: 81,5 KB ID: 3573112​​
            • Biga73
              • Nov 2017
              • 27
              • Ukraine
              Exactly the same board. Starts only from battery. I will take measurements later
              • pc_okay
                • May 2022
                • 244
                • FRANCE
                Guys do you try to change dc jack? check voltage on pin 3 supposed to be 0V.
                They often break and sometime 19V leaking on pin 3.
                Not the same laptop but same fragile connector: (i see some laptop with same problem since this one! easy repair)
                https://www.badcaps.net/forum/troubl...b-dc-or-type-c
                • master3112
                  • Mar 2024
                  • 89
                  • Slovakia
                  That's not possible. No way. My device does not have a PIN in the DC socket. Probably broken off. You're right pc_okay ​ the PIN must normally be connected to ground. I have manually connected the pin to ground and the device starts. So much work because of one contact. Thank you for this tip. Now I order a new DC socket. Well, at least I got to know the device in detail
                  • pc_okay
                    • May 2022
                    • 244
                    • FRANCE
                    Yes if you look inside the DC socket you will see it's slightly damaged maybe you will see a little metal moving part in still attached to the case of the DC...
                    Maybe it will be a good idea to add the this reccurent problem to the "Sticky:Laptop battery charging circuit​" what do you think piernov ?
                    • master3112
                      • Mar 2024
                      • 89
                      • Slovakia
                      ​@pc_okay​That would be a good idea. I did look at the diagram thoroughly when troubleshooting, but I still missed the fact that a circuit checks whether the plug is physically plugged in.
                      • master3112
                        • Mar 2024
                        • 89
                        • Slovakia
                        @Biga73What does your device do?
                        • Biga73
                          • Nov 2017
                          • 27
                          • Ukraine
                          Originally posted by master3112
                          @Biga73What does your device do? ​
                          Sorry for not responding for so long. Replacing the connector DC solved the problem.
                          • Lvsitano
                            Asus X532FL 3.2V at source and gate
                            by Lvsitano
                            I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                            First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                            I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                            First...
                            06-26-2024, 02:13 PM
                          • howardc64
                            Macbook Dust-Gate Preventive Cleaning
                            by howardc64
                            Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                            Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                            https://www.ifixit.com/Guide/MacBook...leaning/177920
                            10-09-2024, 10:10 AM
                          • irfan karatela
                            MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
                            by irfan karatela
                            I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
                            I havent found any shorts on the board.
                            I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
                            On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
                            01-20-2025, 07:15 PM
                          • wagivem657
                            Sharp LC-55LE643U, bad gate drivers?
                            by wagivem657
                            Just received a busted Sharp 55" Aquos (LC-55LE643U) from a coworker. He tried swapping all three boards (power, main, TCON) to fix the problem, but it had the same issue. He was kind enough to give me the TV and both sets of boards for free, so I can try to get it working for myself.
                            Unfortunately, I think I may have made the problem (much) worse, but I'm interested to see if the original problem was fixable at all regardless...
                            Pictures show the issues:
                            1. shows what happens when you first turn the TV on. Well, kinda, the white column wasn't there at
                            01-29-2021, 08:13 PM
                          • netgearnetgear
                            D747m_1v3 logic board for remote gate
                            by netgearnetgear
                            Good day,
                            My remote gate stopped working. The company said the main logic board needs replacement. After examining and running a couple of tests, I discovered what looks like a shorted zener diode. Tracing the path on the board it appears to be across a voltage regulator chip (78m05). After reviewing the datasheet for the voltage regulator I thought that it was being used with a zener diode as a voltage boost regulator. However, looking at the layout of the board the "shorted diode" is not connected as in the datasheet. The diode does not have a markings so I am not sure what...
                            06-22-2024, 03:28 PM
