MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
  • irfan karatela
    • Oct 2024
    • 14
    • united kingdom
    I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
    I havent found any shorts on the board.
    I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
    On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...g7hamb8e0-g7ha
  • mon2
    • 14664
    See here:
    https://www.badcaps.net/forum/troubl...arging-circuit
    On charger ICs, often it is the ACDET pin which must be around 2v6 or higher to denote that a valid charger is attached.
    • semajnoerrac
      • Jul 2022
      • 9
      • Philippines
      check BQ chip
      • pc_okay
        • May 2022
        • 243
        • FRANCE
        I think you are facing a more complex system, that you usally see.
        This is a buck/boost converter with double mofset (connected to the big Coil and to the ground).
        So during normal functionning, the charging IC pulse voltage to the gate of the dual mofset to lower the voltage. (with the help of the big coil and caps and ground...)
        This is a typical system on USB-C charging laptop.
        You can't see those pulses with a multimeter, you need and oscilloscope for that.
        But don't worry you don't actually need an oscilloscope for now!
        First check voltage on +VIN rail with adapter only, you may find battery voltage approximatively. (without the battery plugged).
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • redbaron1007
          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
          by redbaron1007
          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
          09-09-2025, 11:10 AM
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • Romchik
          Schematic&Boardview Quanta G7HA
          by Romchik
          Hello all! I need Schematic&Boardview Quanta G7HA. Thanks for help.
          10-29-2022, 11:22 AM
        • MicroSMD Lab
          by MicroSMD Lab
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
