What is the voltage?
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Hi Guys
    I need a little help about this hp dv7, when start, it turn on but with black screen, now i try with the schematic LA-9042P to check on the LVDS CONN that evry pin get the right voltage, but on the +LCDVVD and C479 i don't get any voltage and i can't cee what for voltage that has to be neither, can anyone tell me what is the voltage for that, plus the voltage for usb20 P5 and N5,
    Hope you guys can help.
    [cee picture]
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
  • SteveNielsen
    Retired Tech
    • 2327
    Re: What is the voltage?
    Not sure about +LCDVDD but would be within 3 to 5v depending on what the LCD panel uses, the USB20 P5 and N5 are data i/o + and -, you're not likely to measure any voltage with a meter there.
    • Life Goes On
      • May 2014
      • 264
      • Curacao
      But i have 0 volt on the +LCDVDD, do you have any idea where i can find that right voltage for, and where the voltagre came from in the schematic, cuz i can't find that neither.
        3V 80 milliAmp, It comes from the main board through the switched MOSFET Q43 (P CH). Q144A control the GATE BIAS for Q43, When Gate of Q144A (N CH) is HIGH (VGA_ENVDD, VGA ENABLE SIGNAL), Q43 is ON, when it is LOW, then Q43 is BIAS OFF.
        • Life Goes On
          • May 2014
          • 264
          • Curacao
          But on the 16 VGA_ENVDD and the R276 i don't have any voltage,
          what do you think s that ok or not?
            That signal is generated by the mother board, it should go high once the laptop boots up, if not, you will need out the connection in the SCH to see where that control line goes to. It should change state when the laptop is switched between on and off.
            • Life Goes On
              • May 2014
              • 264
              • Curacao
              It come from U5F page 16, take a look, and tell me what you think.
                Do you get all three voltages feeding that U5F?
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Reflow gpu.
                  • Life Goes On
                    • May 2014
                    • 264
                    • Curacao
                    Yep all three
                    • Life Goes On
                      • May 2014
                      • 264
                      • Curacao
                      Originally posted by atsio
                      Reflow gpu.
                      i did, but did not work.
                      • Fernon@Repair
                        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                        by Fernon@Repair
                        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                        VCCIO voltage ok
                        VCCSA Voltage OK
                        VCCPLL Voltage OK
                        Ram Voltage ok
                        RamVTT OK
                        VPP 2.5 OK
                        But No Core Voltage
                        and i want to this vrm ic datasheet or pinout (ISL69269)
                        anyone have this ic pinout voltages?...
                        Yesterday, 07:19 AM
                      • electron_jj
                        Panasonic TH-L42D25A checking the PSU output voltage
                        by electron_jj
                        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                        08-29-2021, 08:13 AM
                        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                        by sam_sam_sam
                        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                        Now...
                        06-09-2024, 10:57 AM
                        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                        Based on Intersil's Robust Ripple Regulator...
                        11-05-2024, 03:24 PM
                      • ruletero
                        Acer a515-43 low battery charge voltage
                        by ruletero
                        Hi
                        Acer A515-43
                        LA-H801P
                        Fail: Does not charge battery, has low voltaje on connector.
                        Laptop didn't want to turn on, only charge led blinked.
                        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                        10-24-2022, 02:31 PM
