MacBook Air A2337 M1
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Please tell me what degrees should be used to remove the M1 processor?
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    transferred the processor but can't pass DFU. Apple logo turns on and progress is interrupted. and error 10 appears. what else needs to be transferred along with the processor?
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      after transferring u5000, the MacBook was restored but there is no network. I suspect that the Wi-Fi module also needs to be transferred?
      • PITERPENY
        • Jul 2023
        • 461
        • Ukraine
        as I assumed, the WiFi chip also needs to be moved, otherwise the network won't work. total: for the successful operation of the m1 processor on the new board, only 3 chips need to be moved.
        • reformatt
          • Feb 2020
          • 1491
          Good skills. Curious what BGA rework machine you are using?
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            I use the most basic tool that everyone has at hand.
            • hoang sonw
              macbookviet
              • Feb 2021
              • 7
              • Viet Nam
              You are missing the U0500 embedded rom
              • hoang sonw
                macbookviet
                • Feb 2021
                • 7
                • Viet Nam
                But the chip need to move U0600 , U0500, U1970 ,UL000
                • PITERPENY
                  • Jul 2023
                  • 461
                  • Ukraine
                  • PITERPENY
                    • Jul 2023
                    • 461
                    • Ukraine
                    You are absolutely right about U0600, U0500, U0500, UL000 (I forgot), but I have not transferred U1970 and the MacBooks work properly! What is U1970 responsible for? I tried to install U1970 with MDM (like with T2) on MacBooks to remove MDM, but there is no serial number on this chip. The Mac remains with MDM. How did you solve this problem?
                    • hoang sonw
                      macbookviet
                      • Feb 2021
                      • 7
                      • Viet Nam
                      mdm on apple m1 has no solution. Series is in apple m1
                      • junior_desampa
                        • Aug 2022
                        • 29
                        • Brasil
                        Hi, just one question?
                        Isn't there MDM unlocking on the M1/M2/M3 series?​
                        • PITERPENY
                          • Jul 2023
                          • 461
                          • Ukraine
                          Hi, no
                          • rounin
                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                            by rounin
                            🛠 Original Issue
                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                            04-19-2025, 01:18 AM
                          • mkdj
                            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                            by mkdj
                            About me, my goal and the equipment I (don't) have:
                            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                            About my issue and my goal:
                            A friend of mine has a MacBook Air M1 A2337 that does not...
                            04-03-2025, 08:28 AM
                          • Adogabriel100
                            where to get trusted CD3217. Problem with A2337 Macbook Air
                            by Adogabriel100
                            Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                            The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                            09-06-2024, 12:06 PM
                          • Skrndelj
                            Apple Macbook Air M1 A2337 Trackpad problem
                            by Skrndelj
                            Hello all,
                            I am repairing a Macbook A2337 and i have a problem
                            The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                            When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                            I inspected the whole board and everything seems fine.
                            Can anyone help me as i didn't fiddle with trackpad...
                            06-11-2024, 04:26 AM
                          • Patrick501
                            Macbook Air A2337 dead at 5V/0,00A
                            by Patrick501
                            Hey,
                            I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
                            USB Tester: 5V / 0,00A
                            PPBUS_AON: 12,3 V
                            PP5v_S2: 0 V no short
                            PP3v3_S2_UPC: 0 V no short
                            PP1v25_S2: 0 V no short
                            PPDCIN_AON_CHGR_R: 5 V
                            no enable signals for the S2 rails by the U8100
                            both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
                            PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
                            PP1v5_UPC0_LDO_CORE:...
                            11-29-2024, 02:47 PM
