E15 Gen2 Intel i5 - doesnt start & jumping voltage
  • danny34
    • Jul 2024
    • 49
    I have an E15 Gen2 with Intel i5 and need your help.
    It doesn't start and here's what I've already found out:
    All voltages are available.
    However, the PU8 (RT3612) does not switch the mosfets for +VCCIN.
    On the PU8 I measured 3.3V at pin 23 (VRON), but it drops to 0V every about 3 seconds. This voltage comes from the IT8227E.
    VCC from IT8227E has exactly the same symptom. Every 3 seconds the voltage briefly drops to 0V.
    In the end I saw that +1.8VALW (VCC from IT8227E), +0.6VS, +2.5V_DDR & +1.2V drop to 0V every about 3 seconds for about 1 second.
    I now suspected the PU4 (LV5115) of being defective and replaced it. That wasn't successful.
    VCC, PVCC & VSYS on PU4 all have constant voltage.
    Anyone have an idea where I can look?
    Schematic: HERE Post #9
  • mon2
    • Dec 2019
    • 14546
    Go upstream on the power rails. Who is stable?
    Is the voltage to ground @ V9B+ stable or also power cycling ever 3 seconds?
    This is the primary power rail to power the logic board. It may be that the power cycling is occuring due to an excessive current draw or some regulator believing that there is a higher than normal current draw so the regulator is in chirp mode (on/off/on..). This issue can surface if there is a break in the current sense loop of the power rail being monitored.
    Start with the main power rail for the measurement. Perhaps the bios is corrupt and may be worth reflashing but always make a backup of the original before starting. The dedicated bios section should be able to supply a known good bios.
    • danny34
      • Jul 2024
      • 49
      the 9V is stable, as are all other voltages such as +3VALW or +5VAWL. It only affects those described above.
      I just swapped BIOS chip UB4 from my other working E15 G2 i7 board with the latest BIOS version. Same game​
      • mon2
        • Dec 2019
        • 14546
        Is the Vcc to the EC (IT8227E) stable? Is the EC heating up - more than normal? The EC also has its own firmware driven by the SPI bus where the EC is the bus master. If you have the spare working board, consider to swap out the flash device @ U2 (Bono?) used by the EC for testing.
        • danny34
          • Jul 2024
          • 49
          I haven't changed anything, but I no longer have a V9B+. Also 4ohm to ground...
          strange
          where do the V9B+ come from?
          20.7V is still available until after the QB6 and F6101, from there it is called VINT20_IN.​
          • mon2
            • Dec 2019
            • 14546
            V9B+ is from the charger IC. It is taking in the ~20v from the power adapter and lowering to this voltage. The resistance to ground is very much of concern.
            Remove all power.
            Meter in resistance mode. Check the resistance from this same V9B+ rail (place one meter lead here) and the other meter lead onto the VCORE cpu power rail. We are checking the resistance between these 2 points. If the resistance is low, then the high side mosfet on the VCORE rail has leaked and injected this very high voltage onto the CPU.
            Share the resistance measured between these 2 points of interest.
            • danny34
              • Jul 2024
              • 49
              crap. Resistance between V9B+ and VCCIN (at PL12 and also PL13) are 4ohm. Both highside mosfets (PQ16 and PQ19) have a diode test at 0.0V, no matter in which direction...
              Not good news, right?
              thanks for your help
              • mon2
                • Dec 2019
                • 14546
                Yeah, I am afraid not good news. Respectively, this high voltage must have hit the CPU vcore rail.
                • trepachka
                  • Oct 2022
                  • 439
                  In case this still interest you: I had a similar situation with this board. There was a small spill close to PU8. After cleaning the spill, the motherboard kept resetting every 5 seconds or so.
                  Check all sense resistors around PU8, make sure they all measure 2.2 ohms. In my case, one of the resistors connecting 5V line (pin 29) was showing mega ohms. So, I figured there was quite amount of current passed thru it to make it fry.
                  After replacing it, no change but 5V line going into PU8 was restored. I replaced PU8 from a donor board and the motherboard is kicking again.
                  • Fernon@Repair
                    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                    by Fernon@Repair
                    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                    VCCIO voltage ok
                    VCCSA Voltage OK
                    VCCPLL Voltage OK
                    Ram Voltage ok
                    RamVTT OK
                    VPP 2.5 OK
                    But No Core Voltage
                    and i want to this vrm ic datasheet or pinout (ISL69269)
                    anyone have this ic pinout voltages?...
                    06-25-2025, 07:19 AM
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
                    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                    by sam_sam_sam
                    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                    Now...
                    06-09-2024, 10:57 AM
                    ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                    Based on Intersil's Robust Ripple Regulator...
                    11-05-2024, 03:24 PM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
