In case this still interest you: I had a similar situation with this board. There was a small spill close to PU8. After cleaning the spill, the motherboard kept resetting every 5 seconds or so.
Check all sense resistors around PU8, make sure they all measure 2.2 ohms. In my case, one of the resistors connecting 5V line (pin 29) was showing mega ohms. So, I figured there was quite amount of current passed thru it to make it fry.
After replacing it, no change but 5V line going into PU8 was restored. I replaced PU8 from a donor board and the motherboard is kicking again.
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
E15 Gen2 Intel i5 - doesnt start & jumping voltage
Yeah, I am afraid not good news. Respectively, this high voltage must have hit the CPU vcore rail.Leave a comment:
crap. Resistance between V9B+ and VCCIN (at PL12 and also PL13) are 4ohm. Both highside mosfets (PQ16 and PQ19) have a diode test at 0.0V, no matter in which direction...
Not good news, right?
thanks for your help
V9B+ is from the charger IC. It is taking in the ~20v from the power adapter and lowering to this voltage. The resistance to ground is very much of concern.
Remove all power.
Meter in resistance mode. Check the resistance from this same V9B+ rail (place one meter lead here) and the other meter lead onto the VCORE cpu power rail. We are checking the resistance between these 2 points. If the resistance is low, then the high side mosfet on the VCORE rail has leaked and injected this very high voltage onto the CPU.
Share the resistance measured between these 2 points of interest.Leave a comment:
I haven't changed anything, but I no longer have a V9B+. Also 4ohm to ground...
strange
where do the V9B+ come from?
20.7V is still available until after the QB6 and F6101, from there it is called VINT20_IN.Leave a comment:
Is the Vcc to the EC (IT8227E) stable? Is the EC heating up - more than normal? The EC also has its own firmware driven by the SPI bus where the EC is the bus master. If you have the spare working board, consider to swap out the flash device @ U2 (Bono?) used by the EC for testing.Leave a comment:
the 9V is stable, as are all other voltages such as +3VALW or +5VAWL. It only affects those described above.
I just swapped BIOS chip UB4 from my other working E15 G2 i7 board with the latest BIOS version. Same gameLeave a comment:
Go upstream on the power rails. Who is stable?
Is the voltage to ground @ V9B+ stable or also power cycling ever 3 seconds?
This is the primary power rail to power the logic board. It may be that the power cycling is occuring due to an excessive current draw or some regulator believing that there is a higher than normal current draw so the regulator is in chirp mode (on/off/on..). This issue can surface if there is a break in the current sense loop of the power rail being monitored.
Start with the main power rail for the measurement. Perhaps the bios is corrupt and may be worth reflashing but always make a backup of the original before starting. The dedicated bios section should be able to supply a known good bios.Leave a comment:
I have an E15 Gen2 with Intel i5 and need your help.
It doesn't start and here's what I've already found out:
All voltages are available.
However, the PU8 (RT3612) does not switch the mosfets for +VCCIN.
On the PU8 I measured 3.3V at pin 23 (VRON), but it drops to 0V every about 3 seconds. This voltage comes from the IT8227E.
VCC from IT8227E has exactly the same symptom. Every 3 seconds the voltage briefly drops to 0V.
In the end I saw that +1.8VALW (VCC from IT8227E), +0.6VS, +2.5V_DDR & +1.2V drop to 0V every about 3 seconds for about 1 second.
I now suspected the PU4 (LV5115) of being defective and replaced it. That wasn't successful.
VCC, PVCC & VSYS on PU4 all have constant voltage.
Anyone have an idea where I can look?
Schematic: HERE Post #9Tags: None
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?... -
by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
Now... -
by electron_jjHi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
I have been inspecting and testing the capacitors and diodes in the power supply board to try to... -
3+1 Voltage Regulator for IMVP-7/VR12 CPUs
Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
Based on Intersil's Robust Ripple Regulator...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:24 PM -
This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 09:45 AM
- Loading...
