ISL88739 on battery, the lcd flickers
  • clrscr
    • Dec 2020
    • 186
    • sing
    Originally posted by teknikbursa
    Re: Lenovo Yoga 500-14ISK - No battery charge
    find the resistor on image and change it with 10 ohm resistor
    With the ISL88739 ic, the VCC pin corresponds to the CMSRC pin?
    can you tell me , thanks!
    all donations are welcome,
    >>>>> click on this link to donate via PayPal. <<<<<
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    No. The architecture is totally different for both type of charging IC.
    • clrscr
      • Dec 2020
      • 186
      • sing
      My laptop uses the ic ISL88739 in motherboard and has a problem: when plugged in to the charger, it runs normally, but if I unplug it and run it on battery, the lcd flickers. Can you give me a solution?
      • mon2
        • Dec 2019
        • 14659
        Review the 4R7 ohms resistor on pin 20 (VDD) of the charger chip. Remove all power. Meter in resistance mode. Test across the resistor contacts. What is the measurement in ohms?
        • clrscr
          • Dec 2020
          • 186
          • sing
          I checked the 4R7 resistor on pin 20 R ~~ 5 Ohm
          • mon2
            • Dec 2019
            • 14659
            Test the resistor on pin # 18 (DCIN) - sharing a similar schematic.
            Click image for larger version  Name:	dcin_resistor.png Views:	0 Size:	168.0 KB ID:	3520973
            • clrscr
              • Dec 2020
              • 186
              • sing
              Thank you for your reply, I have checked resistor on pin # 18 (DCIN) R = 20 Ohm All parameters remain unchanged. I still don't understand why the device doesn't work properly on battery
              • clrscr
                • Dec 2020
                • 186
                • sing
                • mon2
                  • Dec 2019
                  • 14659
                  This value should be 10 ohms. What voltage is present on pin #18 with the battery? Test also the dual diode that feeds into pin #18.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I bet this unit is charging the battery fine. Right?
                    If so,then there is unlikely to be a problem in charging section.
                    Measure volatge on EDP pins
                    01.On adapter only
                    02. On battery only.
                    However, first try with another compatible screen.
                    • clrscr
                      • Dec 2020
                      • 186
                      • sing
                      I have checked everything is fine (I also replaced the dual diode PD102 ),if replace R = 10ohm, the charging ic does not work. I'm thinking the charging circuit might be good, Do you have any other solution to help me check?
                      • clrscr
                        • Dec 2020
                        • 186
                        • sing
                        01.On adapter only
                        That's right, the charging circuit works fine, the problem is it runs on battery - lcd flickers
                        ​, i also replaced another screen, problem still not solved
                        • mon2
                          • Dec 2019
                          • 14659
                          Which model of laptop do you actually have? What are the markings of your logic board? Do you have a link to the schematics?
                          What is the voltage of your battery? (it is fully charged?)
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            EDP pins measurement not shared. So cant suggest anything further.
                            • Stevedb
                              Stevedb
                              • Feb 2018
                              • 624
                              • Belgium
                              Hi how much voltage do you have on backlight pins on lcd connector on battery . For the fuse and after.
                              • clrscr
                                • Dec 2020
                                • 186
                                • sing
                                I don't have the mainboard diagram.
                                main code: DAG3MMB4AC0 REV: C
                                battery is fully charged: OUT ~~ 17.5V​
                                • clrscr
                                  • Dec 2020
                                  • 186
                                  • sing
                                  I don't have the main diagram, can only check it on EDP in mainboard.
                                  • clrscr
                                    • Dec 2020
                                    • 186
                                    • sing
                                    I have checked it. Everything seems to be fine, do you have a circuit diagram of it?
                                    • mon2
                                      • Dec 2019
                                      • 14659
                                      Attach the power adapter. What is the voltage on the same EDP pins? What is the voltage with the adapter where you have measured 17v5?
                                      To confirm again, the lcd flickers only if operating from battery? No LCD flicker if both the adapter & battery are plugged into the board?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Have you tested with a new screen?
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
