ISL88739 on battery, the lcd flickers
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
************************************************** ***********************************Tags: None -
My laptop uses the ic ISL88739 in motherboard and has a problem: when plugged in to the charger, it runs normally, but if I unplug it and run it on battery, the lcd flickers. Can you give me a solution?************************************************** ***********************************
************************************************** ***********************************Comment
1 Photo************************************************** ***********************************
I bet this unit is charging the battery fine. Right?
If so,then there is unlikely to be a problem in charging section.
Measure volatge on EDP pins
01.On adapter only
02. On battery only.
However, first try with another compatible screen.Comment
I have checked everything is fine (I also replaced the dual diode PD102 ),if replace R = 10ohm, the charging ic does not work. I'm thinking the charging circuit might be good, Do you have any other solution to help me check?************************************************** ***********************************
That's right, the charging circuit works fine, the problem is it runs on battery - lcd flickers
​, i also replaced another screen, problem still not solved************************************************** ***********************************
I don't have the mainboard diagram.
main code: DAG3MMB4AC0 REV: C
battery is fully charged: OUT ~~ 17.5V​
Attach the power adapter. What is the voltage on the same EDP pins? What is the voltage with the adapter where you have measured 17v5?
To confirm again, the lcd flickers only if operating from battery? No LCD flicker if both the adapter & battery are plugged into the board?Comment
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by mkdjHello everyone,
Mark and model: ASUS X571
Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
Tests already made:
- Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
- I have removed... -
I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
by ferah831208Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
- Loading...
