Macbook Air A2337 dead at 5V/0,00A
  • Patrick501
    • Oct 2024
    • 33
    Hey,
    I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
    USB Tester: 5V / 0,00A
    PPBUS_AON: 12,3 V
    PP5v_S2: 0 V no short
    PP3v3_S2_UPC: 0 V no short
    PP1v25_S2: 0 V no short
    PPDCIN_AON_CHGR_R: 5 V
    no enable signals for the S2 rails by the U8100
    both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
    PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
    PP1v5_UPC0_LDO_CORE: 0 V, 0,5V diode mode to gnd
    PP3v3_UPC1_LDO: 3,4 V; 0,5V diode mode to gnd
    PP1v5_UPC1_LDO_CORE: 1,6 V; 0,5V diode mode to gnd
    when I switch the power supply to the other USB-C Port, it's the other way around. So this looks fine to me as well.
    schematics and boardview: https://www.badcaps.net/forum/troubl...creen-provisor
    ​also I considered this https://repair.wiki/w/MacBook_Air_A2...w_at_5V_repair
  • Patrick501
    • Oct 2024
    • 33
    I had some time to continue and I found out:
    CC1 1,6V on UF400 and UF500 but CC2 is 0 V
    Will it ever switch from 5 to 20V if CC2 is dead?
    • mon2
      • Dec 2019
      • 13849
      CCx are the communication lines for this 1 wire interface used by power delivery. There is CC1 on one side of the USB connector blade. CC2 will be on the opposite half of the USB connector. Only one CCx pin will be active so your measurements so far are accurate.
      Remove the power plug and rotate it by 180 degrees to mate with the opposite half of the connector. Do you now see a voltage on CC2? CC1 will be at 0v since there is no connection on the original side.
      If still @ 0v then suggest to flux and carefully remove the ESD device(s) on the CCx pin that is probably shunting this signal.
      To debug, follow the general guideline for 20v and CD3215 controllers:
      https://logi.wiki/index.php/CD3215_Bootup_Sequence
      Start with confirming that each LDO rail on the CD321x controller is present. The BMC voltage of 1v1 will only be active for the active USB port. Only if each CD321x controller is not defective, then you will have 20v negotiated on the logic board.
      Would you have a thermal camera? To check if there is a shorted part on the board that may be heating up.
      • Patrick501
        • Oct 2024
        • 33
        thanks for your answer!
        it switches, when I rotate the USB-C plug
        I found this link before on here. I think it's a bit different compared to my board since I have the CD3217 (screenshot attached)
        I don't hvae the LDO's and HV_Gates which are listed threre. One or two positions are not even connected (for exampple SMC_RST)
        PP1v5_UPC1_LDO_CORE: 1,6 V; 0,5V diode mode to gnd​
        I can easily find the bmc voltage on the CD3215 but not on the CD3217. Is there another name for it?
        yes, I have one but there's nothing heating up.
        • mon2
          • Dec 2019
          • 13849
          https://logi.wiki/index.php/CD3217_a...er_on_Sequence
          https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
          * A2338 article but may be of help
          Check each LDO rail on these CD3217 ACE controllers.
          You can try a DFU.
          • Patrick501
            • Oct 2024
            • 33
            according to this link and the one for the A2337 it could be a bad U8100.
            PPBUS_AON is also a bit low by 12.28V /diode mode 0.527V
            You can try a DFU.
            I did a DFU twice, but this one won't connect. I also tried different USB ports. I think you can only use the two ports connected straight the logic board. Not sure though... neither of them worked
            there are the voltages of both CD3217. (USB-C connected to UF 400 first, then UF500)
            • mon2
              • Dec 2019
              • 13849
              PPBUS_AON is ok. It is not yet boosted after the SMBUS / I2C communication.
              What is the voltage to ground of the following?
              I2C_SMC_PWR_3V3_SDA
              I2C_SMC_PWR_3V3_SCL
              Test at battery connector J5150 (pins # 3 & # 4).
              The LDO_3V3 rail @ 3v45 seems high. This should be 3v3 and may be of concern. Do you see this exact voltage on the 2nd CD3217 as well? This rail is used to power the SPI firmware boot flash used by these power delivery controllers. Share the above measurements.
              • Patrick501
                • Oct 2024
                • 33
                I2C_SMC_PWR_3V3_SDA
                I2C_SMC_PWR_3V3_SCL
                I2C_SMC_PWR_3V3_SDA: 3.3V
                I2C_SMC_PWR_3V3_SCL: 3.3V
                3.3V both
                yes it's 3.43V on both now. I just double checked with another multimeter.
                • mon2
                  • Dec 2019
                  • 13849
                  The repair wiki article (post #1) still notes that the voltage should be 3v3 for the LDO. The SPI flash is tolerant to 3v6 (max) so it should be ok.
                  See if this is your case here (ironically - still chasing a similar case on a high end iMAC):
                  https://www.youtube.com/watch?v=u4-66f6RFPM
                  • Patrick501
                    • Oct 2024
                    • 33
                    I have the voltage (green) on the coil like in den video but no standby voltages in the red area.
                    Only the PP3V8_AON_VDDMAIN seems present
                    • mon2
                      • Dec 2019
                      • 13849
                      See if the attached helps.
                      Click image for larger version  Name:	a2338_power_sequence.png Views:	0 Size:	335.5 KB ID:	3523917
                      Click image for larger version  Name:	a2338_power_sequence2.png Views:	0 Size:	324.4 KB ID:	3523918
                      Click image for larger version  Name:	a2338_power_sequence3.png Views:	0 Size:	301.9 KB ID:	3523919
                      Click image for larger version  Name:	A2338_d1.png Views:	0 Size:	598.1 KB ID:	3523915
                      Click image for larger version  Name:	A2338_d2.png Views:	0 Size:	480.3 KB ID:	3523916
                      • mon2
                        • Dec 2019
                        • 13849
                        The above should be complete for the power up voltage sequencing diagram. Wait...these are for A2338. Ok, need to drink my coffee. Will still leave it up there. Let me check if A2337 is available for the same.
                        Drugs...or not enough of:
                        A2337 (what I have)
                        Click image for larger version  Name:	A2337_p1.png Views:	0 Size:	165.9 KB ID:	3523926
                        Click image for larger version  Name:	A2337_p2.png Views:	0 Size:	135.8 KB ID:	3523929
                        Click image for larger version  Name:	A2337_p3.png Views:	0 Size:	156.3 KB ID:	3523930
                        • mon2
                          • Dec 2019
                          • 13849
                          Also see if this link works for you:
                          https://academy.chinafix.tech/shipin...SDgriR9LIHM_aA
                          • Patrick501
                            • Oct 2024
                            • 33
                            mon2
                            thanks for the schematics. Unfortunately is has no numbers for the sequence like the one for the A2338 but I will try to figure this out.
                            For some reason I get private messages without text. Do you know what's wrong there?
                            • mon2
                              • Dec 2019
                              • 13849
                              I received your email - check if that came through ok on your side.
                              • Patrick501
                                • Oct 2024
                                • 33
                                for anyone who has the same issue. I don't have a solution yet but meanwhile I checked the power sequences to get 20V.
                                Everything is fine until it reaches the U8100/U7700. There are no output signals, so apparently the sequence ends there. I also checked resistances of the missing output rails./ second step in diode mode.
                                35 ohm seems low but for a cpu rail it should be ok.
                                • mon2
                                  • Dec 2019
                                  • 13849
                                  CPU rail resistance is ok.
                                  Can you confirm your USB C meter with another load? Perhaps your phone? Does the meter report a non-zero current draw? The concern here is if the meter is unidirectional or bidirectional in design. Respectively, if unidirectional, the meter should be used in the direction of their marked arrows.
                                  • Patrick501
                                    • Oct 2024
                                    • 33
                                    I know what you mean, t's an unidirectional. I use it either with adapters or put it straight into the USB power supply to keep it in the right direction, 5.1V@V0,00A
                                    • mon2
                                      • Dec 2019
                                      • 13849
                                      From the repairwiki, missing S2 rails may be due to corrupt firmware.
                                      CD3217 support S2 rails low or missing
                                      * same as you cited in post # 1
                                      I would consider the firmware replacement of U1970 before anything else.
                                      • Patrick501
                                        • Oct 2024
                                        • 33
                                        I assume the only possibility to do this is the way it was done here?
                                        • chipsetrepair
                                          Macbook Air A2337 M1 Wifi module dead
                                          by chipsetrepair
                                          Good day,
                                          I have received a MacBook air m1 a2337 model for no power issue and found out the nand ic for wifi short-circuited.
                                          have removed it and now it shows 5v but still no power, I'm finding a sub-board to replace the nand but my question is it will work after replaced?
                                          because some of my friends said, it could turn on but it can't connect to wifi since the data are patched with the CPU.
                                          Has anyone tried this? the customer only requested to get back the data, please advise....
                                          11-29-2023, 11:26 AM
                                        • robka
                                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                          by robka
                                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                          After that the Macbook was dead. It isn't charging anymore.
                                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                          03-02-2024, 02:58 PM
                                        • Adogabriel100
                                          where to get trusted CD3217. Problem with A2337 Macbook Air
                                          by Adogabriel100
                                          Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                          The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                          09-06-2024, 12:06 PM
                                        • Skrndelj
                                          Apple Macbook Air M1 A2337 Trackpad problem
                                          by Skrndelj
                                          Hello all,
                                          I am repairing a Macbook A2337 and i have a problem
                                          The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                                          When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                                          I inspected the whole board and everything seems fine.
                                          Can anyone help me as i didn't fiddle with trackpad...
                                          06-11-2024, 04:26 AM
                                        • Rav_tangle
                                          MacBook Pro 2011 turns on with keyboard light , screen dead
                                          by Rav_tangle
                                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                          is this...
                                          05-31-2024, 04:09 PM
