Macbook Air A2337 M1 Wifi module dead
  • chipsetrepair
    • Nov 2014
    • 26
    • Philipines
    Good day,
    I have received a MacBook air m1 a2337 model for no power issue and found out the nand ic for wifi short-circuited.
    have removed it and now it shows 5v but still no power, I'm finding a sub-board to replace the nand but my question is it will work after replaced?
    because some of my friends said, it could turn on but it can't connect to wifi since the data are patched with the CPU.
    Has anyone tried this? the customer only requested to get back the data, please advise.
  • Patrick501
    Macbook Air A2337 dead at 5V/0,00A
    by Patrick501
    Hey,
    I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
    USB Tester: 5V / 0,00A
    PPBUS_AON: 12,3 V
    PP5v_S2: 0 V no short
    PP3v3_S2_UPC: 0 V no short
    PP1v25_S2: 0 V no short
    PPDCIN_AON_CHGR_R: 5 V
    no enable signals for the S2 rails by the U8100
    both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
    PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
    PP1v5_UPC0_LDO_CORE:...
    11-29-2024, 02:47 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • obelix24
    Macbook Air M1 a2337 - 820-02016
    by obelix24
    I'm working on Macbook air a2337
    It's stuck on 5V.
    I've replaced both CD3217B12 IC's and U8100
    When i connect USB-C ampmeter i'm getting 5V 0.01 - 0.4a and restart ampmeter and again ....
    I tried to connect to another mac and i'm not able to get it to DFU.
    history is that this macbook just died randomly and owner was not able to start it again.
    PPBUS_AON is 12.3V
    i'm missing PP5V_S2 - 0V
    According to repair wiki i've checked https://repair.wiki/w/MacBook_Air_A2...current_draw_c...
    Today, 07:13 AM
  • mkdj
    MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
    by mkdj
    About me, my goal and the equipment I (don't) have:
    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
    About my issue and my goal:
    A friend of mine has a MacBook Air M1 A2337 that does not...
    04-03-2025, 08:28 AM
  • tech_guru
    Macbook Pro 2019 A2141 NAND Shorted
    by tech_guru
    Hello. If you could please help me understand what I am doing wrong...
    This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
    I also replaced the tps power ic for the ssd.
    Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
    08-28-2025, 08:04 AM
