MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
  • Schluchti45
    • Oct 2024
    • 6
    • Austria
    i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
    Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
  • mon2
    • Dec 2019
    • 14111
    If available as an option, consider to source yet another known good battery from Amazon or similar. This is only to rule out the battery as a defect (which is quite possible). You can always return the battery back to Amazon if it is not required. Aside from this, you will need proper tools like a multimeter + screwdriver set to open up the unit for inspection. Hot air soldering tools or someone with these if parts need to be replaced.
    Ifixit is apparently a stable outfit for parts so you can ask them if they have come across DOA batteries. Assuming not, we need to dig deeper to take some measurements.
    Can you post a good pic of what the Coconut Battery tool reveals?
    • piernov
      • Jan 2016
      • 4435
      • France
      Heard from other technicians that iFixit batteries are no better than other random suppliers. They may provide a little bit better customer service than the cheapest Aliexpress listing though…
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        Do the fans spin when you turn on the computer while the battery is connected? If so this would rule out that the battery is defective even if it is new. Very common to get bad batteries from suppliers. It is always better to remove a pre-owned battery and reseal it from an A2141 if you have that chance. They seem to be more reliable than new ones lately.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • Schluchti45
          • Oct 2024
          • 6
          • Austria
          ​the fans turn when the battery is connected but only with the power supply but it is not charged.
          • oxonater
            • Oct 2012
            • 77
            Hi
            Sounds silly but do you have the correct BMU flex had a few issues myself in the past with these (even new ones supplied by Apple)
            Make sure there is a good connection failing this I/O boards could also be and issue have you tried all 4 ports with same result ?
            • mon2
              • Dec 2019
              • 14111
              This logic board was able to charge the battery ok before this replacement?
              The BMS (battery management) flex cable is separate from the rather beefier cabling used to power the unit. Is the larger & beefier cable firmly attached to the main board? The logic board will be able to detect the serial #, brand of the battery using the smaller BMS / BMU flex cable but will show 0 charge current if the other cable is not properly mating with the logic board.
              Be sure the wide head screw has been applied to pressure fit the battery pcb contacts onto the main logic board. If that is missing or is a loose fit, the charge current will be 0A as showing in your posted screens.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • gboone
                820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                by gboone
                Hi, I was given this laptop by my uncle who said:
                • It would occasionally shutdown if not plugged in
                • battery had been replaced
                • touchbar would "strobe"
                I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                BUT
                When powered off, it would at some point have a...
                01-27-2025, 09:12 AM
              • mferna14
                MacBook Air A2681 battery problem after Screen Replacement
                by mferna14
                Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                12-06-2024, 08:10 PM
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • bogosort
                M1 Macbook Air 2337 not booting after changing battery
                by bogosort
                There was a problem with the original battery board so I had to replace it.
                However, the new battery causes the laptop to not boot. The USB-C amp meter shows 5v 0.25a, then jumps to 20v 0.03a and immediately cycles when the battery is plugged in. The laptop boots fine with the battery disconnected.
                Any idea?
                Thank you
                12-18-2023, 12:35 PM
