M1 Macbook Air 2337 not booting after changing battery
This topic has been answered.
  • bogosort
    • May 2022
    • 78
    There was a problem with the original battery board so I had to replace it.
    However, the new battery causes the laptop to not boot. The USB-C amp meter shows 5v 0.25a, then jumps to 20v 0.03a and immediately cycles when the battery is plugged in. The laptop boots fine with the battery disconnected.
    Any idea?
    Thank you
  • Answer selected by bogosort at 12-18-2023, 12:39 PM.
    mon2
    • 14631
    Suggest to test with another but known good battery. Try Amazon so you have a return mechanism in place. Mobile Sentrix sells a good product - if you are a dealer or know of one that can help you.
    • mon2
      • 14631
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Schluchti45
        MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
        by Schluchti45
        i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
        Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
        11-18-2024, 02:05 AM
      • gboone
        820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
        by gboone
        Hi, I was given this laptop by my uncle who said:
        • It would occasionally shutdown if not plugged in
        • battery had been replaced
        • touchbar would "strobe"
        I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
        After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
        BUT
        When powered off, it would at some point have a...
        01-27-2025, 09:12 AM
      • pabloroggeri
        Lenovo V310-15ISK - It doesn't work after changing the battery
        by pabloroggeri
        Good guys. I changed the battery to a Lenovo V310-15ISK.
        The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
        When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
        08-23-2024, 12:01 PM
      • mferna14
        MacBook Air A2681 battery problem after Screen Replacement
        by mferna14
        Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
        12-06-2024, 08:10 PM
