A2442 820-02098 5v 0a - PP3V8_AON short
  • saisoni20
    • Feb 2022
    • 111
    Good afternoon,
    I'd appreciate help diagnosing my A2442 that's only taking 5v and 0a. Magsafe charger is not working.
    PPBUS_AON (Battery unplugged) - ~12.00
    Found out PP3V8_AON is short to the ground. I have feed 1V and U7700 is getting hot.
    Is there any way to isolate U7700 from PP3V8_AON. Just to make sure any other component is not bad which is causing U7700 to get hot.
    Thanks in advance
  • mon2
    • Dec 2019
    • 14342
    Lift one leg on each of the multiphase inductors of PP3V8_AON.
    So this involves:
    L5800
    L5820
    L5840
    • saisoni20
      • Feb 2022
      • 111
      Hi Mon2
      I have tried removing those inductors same U7700 is getting hot.
      • electroelef
        • Jun 2014
        • 57
        • United Kingdom
        I just had the same behaviour. C7714 was shorted. I was lucky.
        • kalum
          • May 2023
          • srilanka
          so guys, in my case PP3V8_AON this line is not stable. UR630 has failed​.
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
