u36sd rev2.1 - chg_en# 0v battery only!
  • infordecima
    • Oct 2024
    • 9
    • portugal
    Good evening, my asus u36sd rev2.1 always has the orange charging LED on when I have the battery inserted, without the charger inserted, without the battery I have chg_en# at 3v everything is fine but when I insert the battery I only have chg_en# to 0v when in reality it should have 3v.
    b24740
    help
  • mon2
    • Dec 2019
    • 14262
    The net name label has a ‘#’ suffix which means this is an active low signal. So when this signal is at 0 volts = logic low, the battery is considered to be attached and vice-versa.
    • infordecima
      • Oct 2024
      • 9
      • portugal
      Bom dia, sim, eu sei disso, o problema é que a bateria só está conectada sem um carregador acoplado e o chg_en# está em 0v, quando deveria estar em 3v.
      Does the value of chg_en# come from ic bq or kbc (ec)?
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        English, please.
        The signal is right if the battery is inserted.
        You seem to have problem with the ac adapter detection. Measure voltages around the BQ chip.
        • infordecima
          • Oct 2024
          • 9
          • portugal
          bq24740
          No battery connected to charger but PC turned off
          1- 3.30
          2- 18.45
          3- 18.45
          4- 0
          5- 2.63
          6- 1.15
          7- 0
          8- 0
          9- 0
          10- 3.30
          11- 3.30
          12- 0
          13- 0
          14- 1
          15- 0
          16- 0
          17- 1.06
          18- 1.06
          19- 1.06
          20- 3.16
          21- 1.74
          22- 0
          23- 0
          24- 5.95
          25- 1.06
          26- 1.06
          27- 5.84
          28- 18.81
          with battery only connected and PC turned off (orange charging LED on)
          1- 0v
          2- 15.45
          3- 15.45
          4- 0.15
          5- 0
          6- 0
          7- 0
          8- 0
          9- 0
          10- 0
          11- 0
          12- 1.31
          13- 3.31
          14- 0
          15- 0
          16- 1.95
          17- 15.67
          18- 15.67
          19- 15.67
          20- 0
          21- 1.09
          22- 0
          23- 0
          24- 0.20
          25- 15.65
          26- 15.65
          27- 15.65
          28- 7.56​
          • mon2
            • Dec 2019
            • 14262
            Check your diode feeding into pin #28 (Vcc) from the battery. The voltage is too low here for the battery only case.
            • infordecima
              • Oct 2024
              • 9
              • portugal
              passes through a capacitor and goes to the diode image below
Name:	Captura de ecrã 2024-10-16 214213.png
              • mon2
                • Dec 2019
                • 14262
                Trace the voltage to ground of the battery on each leg of the diode that feeds onto pin #28 (Vcc). With only the battery attached, the battery voltage should only drop by 0v6 or similar to pin #28. Also this voltage should not reverse leak onto power adapter side of the power path.
                What is the voltage of the raw battery? See ~15v on a few pins and expecting a similar voltage on pin #28.
                • infordecima
                  • Oct 2024
                  • 9
                  • portugal
                  with grounding on the battery and measuring the diode pins, same voltages as the image above, pin 1=0.43, pin 2=0.43v, pin 3=7.48v
                  battery is 15.59v and I measured the battery pins with it connected,
                  I have 15.59v on the pin
                  8 and 9
                  and 3.33 in 4 and 5.
                  • infordecima
                    • Oct 2024
                    • 9
                    • portugal
                    battery is 15.59 and I measured the battery pins with it connected, I have 15.59 on the pin
                    8 and 9 and 3.33 in 4 and 5
                    I don't know where the 7.53v comes from pin28
                    Please note that the computer turns on and works only when the orange LED charging light is always on, even without a charger placed with an indication in the windows that it is charging.
                    • mon2
                      • Dec 2019
                      • 14262
                      Ok. The battery voltage is now confirmed and appears to be OK.
                      Which diode is taking this voltage to power the charger IC @ pin #28?
                      Is it PD8802? If yes, one leg of this dual diode must be at the same voltage as the battery voltage = ~16v to ground.
                      Then pin #28 must receive about the same voltage as the battery voltage (battery voltage - 0v6 for the diode forward voltage drop). If pin #28 is must lower, then PD8802 is defective.
                      • infordecima
                        • Oct 2024
                        • 9
                        • portugal
                        It goes through the pd8802 but it shouldn't be the one sending the battery voltage, maybe the pq8804?
                        The pq8804 seems to me to come from the vin (charger) and another battery pin.
                        The PD8802 pins 1 and 2 (0.46v) are connected.
                        The pr8829 is not on the board, it must come from the factory like this.
                        The second image is pin 28 vin of the load bq that will connect to pin 3 pd8802
                        Click image for larger version  Name:	IMG_20241017_174136.jpg Views:	0 Size:	108.5 KB ID:	3486021
                        Click image for larger version  Name:	IMG_20241017_174143.jpg Views:	0 Size:	56.6 KB ID:	3486022
                        • mon2
                          • Dec 2019
                          • 14262
                          Ok. Confirm that pins # 1 & # 2 on PD8802 have the same battery voltage of ~15v59 volts.
                          Then pin #3 on PD8802 should be about 0v6 lower than the input voltage so around 15v on pin #28 of the charger IC.
                          If not, then PD8802 should be replaced. Since Asus schematics are in the witness protection program, the schematics are rare. You will need to trace out this region of the circuit and post all details here. Which exact part / diode mates to pin #28 (Vcc) of the charger IC. Assuming it is PD8802 or another, the voltage should not be so low when you attach the battery on the Vcc pin.
                          • infordecima
                            • Oct 2024
                            • 9
                            • portugal
                            pin #1 and #2 of the PD8802 have 0.46V and #3 7.48v when it should have 15v, as this pin goes to pin #28 of the load ci.
                            I'm going to replace the pd8802 to check if the #3 voltage goes up.
                            • mon2
                              • Dec 2019
                              • 14262
                              Hunt for the diode that has the battery voltage on pins 1 or 2. That is the diode of interest. It is not this one since you have a very low voltage at pins 1&2. You can remove it to see if this part is reverse leaking.
                              • infordecima
                                • Oct 2024
                                • 9
                                • portugal
                                I didn't find any diode in the charging bq power circuit, just that pd8802 is normal?
                                Now I don't know where the 7.53v from the pd8802 comes from.
                                I already changed the pd8802 and the behavior remains
                                I attach the boardviewer to help me please
                                • mkdj
                                  ASUS X571 no power : battery issue?
                                  by mkdj
                                  Mark and model: ASUS X571
                                  Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                  Tests already made:
                                  - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                  - I have removed...
                                  07-14-2025, 09:16 AM
                                • techfreak9356
                                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                  by techfreak9356
                                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                  09-14-2023, 11:10 PM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                • ferah831208
                                  Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                  by ferah831208
                                  Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                  03-18-2025, 01:18 AM
                                • huzo
                                  HP ELITE X2 1013 G3 weird battery issue
                                  by huzo
                                  Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                  01-31-2025, 12:09 AM
