MBP A1286 820-2915 green light only, no start
  • blazzelia
    • Nov 2019
    • 40
    Not yet, will do it and report back. Thanks
    • piernov
      • Jan 2016
      • 4439
      • France
      C9560 failure is a problem on 820-2850 not 820-2915.
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        be very carefull that the psu is in perfect working condition as some charger give green light but fail to power on the board. also bad battery can lead to this problem too.
        try smc bypass if it start:
        short the 2 pins on board, then connect psu while keeping the two pads shorted, then release the pin and short them again. check if pc start with full fan spin and give post and screen.
        • blazzelia
          • Nov 2019
          • 40
          Originally posted by kevingill
          Have you replaced C9560 BTW?
          I've checked its value - it has 300uF (the schematic says it should be 220uF). In any case, it seems to be ok. The voltage levels are unchanged without this capacitor.
          • blazzelia
            • Nov 2019
            • 40
            I did that, the fans won't start, the voltage levels are unchanged, the pulsing rails still pulsing.
            • blazzelia
              • Nov 2019
              • 40
              #26
              Any other idea?
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                #27
                read voltage on C7205 pin N° 1
                check voltage of r7940 both side,
                post u7201 voltage.
                • blazzelia
                  • Nov 2019
                  • 40
                  #28
                  Sorry for the delay ... long working hours ...
                  So, ping 1 on C7205 - oscillating
                  Same for both sides of R7940.
                  Regarding U7201, do you mean the voltage on all pins?
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    #29
                    voltage on c7200,
                    resistance on c7205 ?
                    • blazzelia
                      • Nov 2019
                      • 40
                      #30
                      voltage on c7200,... ?
                      Very confusing ... the board was sitting on my desk since my last reply, so about 3 weeks away. At first the voltmeter showed 3.7-5V, then up to 12.4, then down again, then 12,4 for minutes until I got bored waiting for a change. Powered off, tried again - 12.4V. I put the MB away and check it the next day - 12.4V. At some point I just left the MB powered on, decided to get back to it in about half hour. After a few minutes the green light from the magsafe went off. I reconnected it - green light and 12.4V, and the magsafe did not go off. Not sure if that tells anything...
                      The resistance on C7205 starts at around 20 Mohms going down to 4 MOhms.
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        #31
                        your macbook has some problem with ppbus and smd. 12,4 volt going down could be bad 10omh resistor r7021, r7022. check if they are 10omh.
                        • blazzelia
                          • Nov 2019
                          • 40
                          #32
                          R7021 and R7022 are both intact and have 10 Ohms.
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            #33
                            board should not power on on 12,4 volt unless u do smcbypass. ppbus must be 12,57 volt (12,6) not 12,4 as smc is not boosting. if u connect fan, and connect psu, fan start spinning or they dont ?
                            • blazzelia
                              • Nov 2019
                              • 40
                              #34
                              No fans spinning...
                              • blazzelia
                                • Nov 2019
                                • 40
                                #35
                                Originally posted by blazzelia
                                No fans spinning...
                                What does it means?
                                • blazzelia
                                  • Nov 2019
                                  • 40
                                  #36
                                  Any other idea?
                                  • mon2
                                    • 14672
                                    Measure the voltage to ground of:
                                    SMBUS_SMC_BSA_SCL
                                    SMBUS_SMC_BSA_SDA
                                    on J6950 (battery connector). Post the voltage measurements.
                                    • MOSSEP
                                      Monitor Audio RSW12 - Green light, but no sound
                                      by MOSSEP
                                      Hi
                                      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                      I have already tried replacing all of the...
                                      01-26-2025, 08:33 AM
                                    • MOSSEP
                                      Monitor Audio RSW12 - Green light but no audio
                                      by MOSSEP
                                      Hi
                                      01-26-2025, 08:18 AM
                                    • lcdcaps1
                                      820-2610-A Sys onewire help, no green light. Please help from the gurus
                                      by lcdcaps1
                                      Hi
                                      I have an 820-2610-A motherboard that has no green light.
                                      I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                      From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                      The sys onewire circuit on this model and others is more involved
                                      I was hoping if anyone knows about this and how it works, can reply and let me know
                                      I know this is an old model but I am sure there are people who still works on these or knows about them
                                      I get 1.1v on the C7771 capacitor and will replace...
                                      11-06-2023, 01:28 PM
                                    • jheunne
                                      A1466 macbook no boot green to orange light help
                                      by jheunne
                                      i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                      in first image there is 0v out for lcd
                                      https://ibb.co/5XppmpkH
                                      in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                      https://ibb.co/fdJkbJs8
                                      06-10-2025, 10:52 PM
                                    • techrepairheide
                                      MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
                                      by techrepairheide
                                      Hello again,
                                      got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
                                      Device died over night on charger.
                                      Currently I did the follow things:
                                      1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
                                      2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
                                      3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
                                      01-26-2025, 05:37 AM
