MBP A1286 820-2915 green light only, no start
  • mon2
    replied
    Measure the voltage to ground of:
    SMBUS_SMC_BSA_SCL
    SMBUS_SMC_BSA_SDA
    on J6950 (battery connector). Post the voltage measurements.
  • blazzelia
    replied
    Any other idea?
  • blazzelia
    replied
    Originally posted by blazzelia
    No fans spinning...
    What does it means?
  • blazzelia
    replied
    No fans spinning...
  • dellxps15
    replied
    board should not power on on 12,4 volt unless u do smcbypass. ppbus must be 12,57 volt (12,6) not 12,4 as smc is not boosting. if u connect fan, and connect psu, fan start spinning or they dont ?
  • blazzelia
    replied
    R7021 and R7022 are both intact and have 10 Ohms.
  • dellxps15
    replied
    your macbook has some problem with ppbus and smd. 12,4 volt going down could be bad 10omh resistor r7021, r7022. check if they are 10omh.
  • blazzelia
    replied
    Originally posted by dellxps15
    voltage on c7200,... ?
    Very confusing ... the board was sitting on my desk since my last reply, so about 3 weeks away. At first the voltmeter showed 3.7-5V, then up to 12.4, then down again, then 12,4 for minutes until I got bored waiting for a change. Powered off, tried again - 12.4V. I put the MB away and check it the next day - 12.4V. At some point I just left the MB powered on, decided to get back to it in about half hour. After a few minutes the green light from the magsafe went off. I reconnected it - green light and 12.4V, and the magsafe did not go off. Not sure if that tells anything...
    The resistance on C7205 starts at around 20 Mohms going down to 4 MOhms.
  • dellxps15
    replied
    voltage on c7200,
    resistance on c7205 ?
  • blazzelia
    replied
    Sorry for the delay ... long working hours ...
    So, ping 1 on C7205 - oscillating
    Same for both sides of R7940.
    Regarding U7201, do you mean the voltage on all pins?
  • dellxps15
    replied
    read voltage on C7205 pin N° 1
    check voltage of r7940 both side,
    post u7201 voltage.
  • blazzelia
    replied
    Any other idea?
  • blazzelia
    replied
    try smc bypass if it start:
    short the 2 pins on board, then connect psu while keeping the two pads shorted, then release the pin and short them again. check if pc start with full fan spin and give post and screen.
    I did that, the fans won't start, the voltage levels are unchanged, the pulsing rails still pulsing.
  • blazzelia
    replied
    Originally posted by kevingill
    Have you replaced C9560 BTW?
    I've checked its value - it has 300uF (the schematic says it should be 220uF). In any case, it seems to be ok. The voltage levels are unchanged without this capacitor.
  • dellxps15
    replied
    be very carefull that the psu is in perfect working condition as some charger give green light but fail to power on the board. also bad battery can lead to this problem too.
  • piernov
    replied
    C9560 failure is a problem on 820-2850 not 820-2915.
  • blazzelia
    replied
    Not yet, will do it and report back. Thanks
  • kevingill
    replied
  • blazzelia
    replied
    It's looks as though it's trying to get to S0 with PP3V3_S0 pulsing. However, PP5V_S3 is at 0. I'd take a good look around U7201 to find out the issue.
    Have you removed all non essential cables/RAM/etc?
    RAM was still in but the signals are the same without it.
    I pulled C7205 to measure it - 9.6uF. When I measure the voltage on it (PP5V_S5) there is a clicking noise - I guess it's comming from one of the inductors from the back of the board.
  • blazzelia
    replied
    Originally posted by mon2
    Not shorted. Check the EN pins on the regulator IC that creates the above rails. Are they also pulsing? Check if you are missing any current sense resistors which can result in the regulator believing there is a too high of a current draw since the feedback is missing and will power cycle the rail(s).
    Two of the EN signals also pulsing, one in 0V. The current sensing resistors are fine.
  • MOSSEP
    Monitor Audio RSW12 - Green light, but no sound
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:33 AM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    01-26-2025, 08:18 AM
  • lcdcaps1
    820-2610-A Sys onewire help, no green light. Please help from the gurus
    by lcdcaps1
    Hi
    I have an 820-2610-A motherboard that has no green light.
    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
    The sys onewire circuit on this model and others is more involved
    I was hoping if anyone knows about this and how it works, can reply and let me know
    I know this is an old model but I am sure there are people who still works on these or knows about them
    I get 1.1v on the C7771 capacitor and will replace...
    11-06-2023, 01:28 PM
  • jheunne
    A1466 macbook no boot green to orange light help
    by jheunne
    i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
    in first image there is 0v out for lcd
    https://ibb.co/5XppmpkH
    in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
    https://ibb.co/fdJkbJs8
    06-10-2025, 10:52 PM
  • techrepairheide
    MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
    by techrepairheide
    Hello again,
    got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
    Device died over night on charger.
    Currently I did the follow things:
    1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
    2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
    3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
    01-26-2025, 05:37 AM
