Macbook A2338 820-02020-A No power
  • tommy97
    • Mar 2023
    • 151
    • United Kingdom
    Hi guys,
    I'm having problems with 820-02020-A, to start with macbook came with liquid damage, I cleaned the board, and it worked, however fan was on the full speed from the start. After while stop switching on, stuck on 5V 0amp draw.
    PPBus_AON 1v
    Replaced CD3217 - both as they were liquid damaged.
    Replaced ISL
    Checked current sense resistors next to ISL, values in order.
    R5221 — 1.00 Ω
    R5222 — 1.00 Ω
    R5261 — 1.00 Ω
    R5262 — 1.00 Ω
    PP3v8_AON​ - missing as well _EN is missing
    PPDCIN_AON_CHGR_R 5.17V
    LDO's 5v
    Checked all above - None of them are shorted.
  • mon2
    • Dec 2019
    • 14191
    What is the resistance to ground of PPBus_AON?
    What is the voltage to ground of:
    I2C_SMC_PWR_3V3_SCL
    I2C_SMC_PWR_3V3_SDA
    at the battery connector J5151?
    • tommy97
      • Mar 2023
      • 151
      • United Kingdom
      I2C_SMC_PWR_3V3_SCL - 0.03V
      I2C_SMC_PWR_3V3_SDA
      - 0.03V
      PPBus_AON​ on C5403 30M OHm and goes down.
      • mon2
        • Dec 2019
        • 14191
        Remove all power. Meter in resistance mode.
        What is the resistance to ground of:
        I2C_SMC_PWR_3V3_SCL
        I2C_SMC_PWR_3V3_SDA
        • tommy97
          • Mar 2023
          • 151
          • United Kingdom
          Both are at about 4 M Ohm cycling up and down, checked on the 2nd board looks the same.
          • mon2
            • Dec 2019
            • 14191
            So no shorts here but missing the prerequisite / upstream voltages required to pull-up these open-drain lines.
            With no power to the board, what is the resistance to ground of the following?
            PPBus_AON ; measure @ F5200 (both sides of the fuse)
            Next, flux and remove the fuse at F5200. Then power up again. What is the voltage now of F5200 pcb pad #1? Is it stable?
            • tommy97
              • Mar 2023
              • 151
              • United Kingdom
              F5200 - PPBUS_AON 0.8V (And goes down), PPVBAT_AON 1.065V Stable.
              While fuse removed resistance on PPBUS 7M OHm and goes down on PPVBAT_AON 12M Ohm
              • mon2
                • Dec 2019
                • 14191
                With the fuse removed, power up. What is the voltage to ground at the pcb pad of removed fuse?
                • tommy97
                  • Mar 2023
                  • 151
                  • United Kingdom
                  PPBUS_AON 0.8V (And goes down), PPVBAT_AON 1.065V Stable. Those one are after fuse removed
                  • mon2
                    • Dec 2019
                    • 14191
                    Measure the voltage to ground of
                    PPDCIN_USBC_AON ; this is the input voltage rail to the ISL9240 (U5200) that creates PPBUS_AON
                    CHGR_AUX_DET ; at junction of R5215 & R5216
                    PP1V8_S2 ; @ C5280
                    • tommy97
                      • Mar 2023
                      • 151
                      • United Kingdom
                      PP1V8_S2 ; @ C5280 = 0V & 2.5 k OHm
                      R5215 - PPDCIN 5V - CHGR_AUX_DET ​1.2V
                      R5216 - 1.2V CHGR_AUX
                      • tommy97
                        • Mar 2023
                        • 151
                        • United Kingdom
                        mon2 Have you got any idea for it?
                        • mon2
                          • Dec 2019
                          • 14191
                          With no load (no downstream fuse) and 5v as the power adapter voltage, the ISL9240 should enter boost mode and offer ~12v. If PD = 20v, then the ISL will enter buck converter mode and lower the input voltage to the ~12v output. If the current sense resistors are ok then suspecting the ISL to be defective. What does the visual inspection show? Was this chip replaced or reworked?
                          With no power, check the diode mode values against the attached.
                          • tommy97
                            • Mar 2023
                            • 151
                            • United Kingdom
                            mon2 i've replaced once more ISL, and 12.28V come back however fan spin 100%, laptop power on and display.
                            I2C_SMC_PWR_3V3_SCL 3.3v
                            I2C_SMC_PWR_3V3_SDA
                            ​ 3.3v
                            UC710 - replaced / no change.
                            PPBUS_AON_3V3S2_VIN_ISNS 12.28V
                            • mon2
                              • Dec 2019
                              • 14191
                              Try a DFU:
                              https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                              • bigbadbios
                                a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
                                by bigbadbios
                                I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
                                When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
                                I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
                                Your help is GREATLY appreciated. Thanks!
                                08-18-2024, 05:47 PM
                              • dbuergi
                                MacBook Pro A2338 liquid damage repair for a beginner?
                                by dbuergi
                                i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
                                I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
                                Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
                                I fixed other laptops but this ist my first apple device ....
                                07-24-2024, 09:48 AM
                              • fajfelek
                                Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
                                by fajfelek
                                Hello, First of all thanks you for reading this topic.
                                I need your help with identify missing parts on trackpad logic board (661-18430).
                                The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
                                Please help me with identity parts from blue and red area .
                                06-15-2024, 01:41 PM
                              • mon2
                                A1466 Macbook Air (Liquid damage repair)
                                by mon2
                                Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                Macbook AIR Model A1466 Diagnostic 09-01-2021
                                Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                Problems & Resolutions
                                1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                09-01-2021, 09:31 AM
                              • mitchw
                                MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                by mitchw
                                Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                I quickly took it apart and washed the liquid residue off the mainboard.
                                The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                Now the laptop...
                                07-16-2025, 07:55 AM
