MacBook Pro A2338 liquid damage repair for a beginner?
  • dbuergi
    • Jul 2024
    • 137
    • Deutschland
    i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
    I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
    Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
    I fixed other laptops but this ist my first apple device .
  • mon2
    • 14677
    Hi. Highly suggest to purchase some donor boards for training on soldering and removal of such tiny WLCSP packaged parts like this intersil 9240hi.
    The intersil 9240hi is available from Aliexpress.
    ISL9240 - Buy ISL9240 with free shipping on AliExpress
    • dbuergi
      • Jul 2024
      • 137
      • Deutschland
      Hello mons2,
      thank you for your reply. Do you have any tipps for tools to work on these parts? As stated i worked on boards and have a hot air station, soldering irons and a digital microscope. Would it be easier to use low melt solder or solder paste for such small parts?
      • PITERPENY
        • Jul 2023
        • 461
        • Ukraine
        looking at what's going on around the isl, everything under the isl is corroded! before buying a new isl, reball the old isl! you have all the tools! buy a stencil right away, if not, for the isl and soldering paste for rolling the balls and flux! this will be enough to replace it and all the other components!
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • rounin
          MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
          by rounin
          Device Information
          • Model: MacBook Pro 14” M1 Pro (A2442)
          • Logic board number: 820-02443-05
          Original Issue
          The device suffered liquid damage, causing a short circuit on the logic board.
          Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
          Work Performed
          Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
          Current Status
          • When powered on, the screen shows support.apple.com/mac/restore....
          10-20-2025, 11:15 PM
        • fajfelek
          Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
          by fajfelek
          Hello, First of all thanks you for reading this topic.
          I need your help with identify missing parts on trackpad logic board (661-18430).
          The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
          Please help me with identity parts from blue and red area .
          06-15-2024, 01:41 PM
        • rilley
          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
          by rilley
          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
          And the resistor L4004 is literally burned.
          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
          07-10-2024, 01:57 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
