A2337 - Camara doesn't work
  • soeren
    • Apr 2024
    • 16
    I have replaced the display on my A2337 and I believe that during the change the battery connector was re-connected to the logic board and therefore I now have a non-working camera in my A2337 laptop.
    After the problem occurred, the camera was no longer detected and True Tone didn't work. I replaced the eDP flex cable (display connector) and now the camera is detected and True Tone works again.
    The problem is that when I open Facetime, for example, the green camera LED does not light up and the camera image remains black. In the end I get an error message. Does anyone know what is fried on the logic board or where I could start looking?
    Thanks.​
  • lee20242024
    • Aug 2024
    • 5
    • Fiji
    Lock
    • soeren
      • Apr 2024
      • 16
      What do you mean with "Lock" ?
      • CuriousDave
        • Aug 2024
        • 11
        So I assume it is 820-02016 which I don't have the board view or schematic. I had the issue with a 16in a while back after replacing the battery. Took all day to catch the little guy after wondering what is the root cause. Check the pin 29 to 31 on the connector in diode mode.That is the most common problem. If I have the schema, I may be able to look up and point out which one to check.
        • CuriousDave
          • Aug 2024
          • 11
          I had another one with no camera after removing the board and reassembled. The Ferrous inductor for the camera was burnt. There is nothing serious if you look at the circuit for camera. Mostly the inductor just died.
          • hollox123
            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
            by hollox123
            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
            1. Laptop keyboard doesn't work
            2. The backlight on the laptop keyboard doesn't work
            3. The x2 side LEDs (red) on the laptop don't work
            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
            But I am strongly aiming that it is somehow a BIOS-related problem,...
            05-11-2025, 08:05 AM
          • resistor83
            lenovo 330s-15ikb, led num lock key always on and numbers don't work
            by resistor83
            hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
            I tried updating the bios but the problem remains
            https://s...
            05-29-2025, 08:06 AM
            DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
            by sam_sam_sam
            I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
            If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
            One —>the LEDs might be bad
            Two —> the buck converter or regular might be bad
            Three —> the controller might not...
            08-08-2023, 05:12 PM
          • redwire
            Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
            by redwire
            My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
            Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
            Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
            The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
            The tone caps are green film caps I left alone. Newer...
            07-30-2023, 08:21 PM
          • pni
            Lenovo ideapad3 15ada05 touchpad doesn’t work the clicking
            by pni
            Hi, I bought this laptop Lenovo ideapad 3 15ada05. The problem is on the touch pad. Everything works good also the touchpad. But when I click and I hear the sound of the clicking on the touchpad I don’t have nothing…all work but the clicking no…I tried to update bios, reinstalling window 11, update the driver on the Lenovo site. But nothing. The clicking didn’t work, someone can help me thanks
            12-08-2025, 07:21 AM
