Lenovo N500 - No power
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: Lenovo N500 - No power
    when i remove PQ5 same thing happen, voltages still osctilates
    ...the quieter you become the more you are able to hear...
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      i try to remove PQ19 and now i have 0V on that rail that i have earlier oscilating voltages
      • spleenharvester
        • Mar 2010
        • 921
        That's pretty peculiar. B+ is connected to PU10, and since removing PL12 stops the oscillation, and since removing PQ5 does not stop the oscillation, that suggests that any component between PL12 and PQ5 could be bad. So PC39, PC38, PC37, PC36, PC150, PR17, PC13, PC8, PC1, maybe even PU1 itself.
        Or whatever the hell is connected to CHG_B+.
        Again, I could be wrong! I'm no professional at this. It might be worth checking PQ32 and PQ34
        EDIT: If it did work on battery PQ32 and PQ34 would be okay, actually. Which would also mean B+ is fine and it's something charger-related (I suppose CHG_B+ could still be at fault)
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
        • spleenharvester
          • Mar 2010
          • 921
          Just took another look, this isn't making much sense to me. Presumably, voltage would be flowing through those components while on battery anyway? And if it was indeed working on battery, this suggests the problem is elsewhere?
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            i found the problem, it was solder bridge on PQ19, now i have 17V on that rail, and 3V on BIOS
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              #26
              uhh i will go crazy with this one, i have 16.9 and 17.10 oscilating voltage on that rail. Laptop still wont start
              • whaldsz
                • Apr 2013
                • 395
                • Philippines
                #27
                there is a possible leaky capacitor or fet along the 19v rail. you should use your bench power supply to isolate it.
                • khaahk
                  • Dec 2013
                  • 818
                  • Estonia
                  #28
                  Such a small variation should not interfere with startup. The b+ rail can be from 19v to battery voltage. But it indicates that something is wrong. On pg 46, the oscillation is at pq38 drain only or source also? +5alw and +3v exist and are stable?
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    #29
                    this is crazy i check now and i have stable 14.8V on drain of PQ38. Source is 19V.
                    On PU10 3V output is 0V and 5v output is oscilating 0-4v
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      #30
                      ahh now again oscilating voltage at PQ38
                      • gorip
                        • Mar 2014
                        • indonesia
                        #31
                        have you ever tried to clean up these area? . insect pee sometimes leave no trace
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • Mita99
                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                          by Mita99
                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                          04-27-2025, 07:20 PM
                        • Dr.d
                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                          by Dr.d
                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                          04-05-2024, 11:48 AM
