Recognising an item on a MacBook Pro 13" 2020 A2251 motherboard
This topic has been answered.
  • Kristion
    • Aug 2024
    • 7
    • France
    Hi there, I had a MacBook Pro 13" 2020 A2251 at work, and it suddenly stopped working without having being bad to it (I ride my bike everyday though). I replaced the motherboard so now it works again, but with other data. I would like to repair the 661-15938 motherboard. I spotted where it burned, I saw that there is a post where there are the 820-01949 pdf and bvr but I don't know what to do with it. I tried to install OpenBoardView because it seems like it's what I should use to have a look at the schematic view of my motherboard. But I failed:
    $ git clone --recursive 'https://github.com/OpenBoardView/OpenBoardView'
    Clonage dans 'OpenBoardView'...
    remote: Enumerating objects: 6084, done.
    remote: Counting objects: 100% (1286/1286), done.
    remote: Compressing objects: 100% (477/477), done.
    error: échec RPC ; curl 92 HTTP/2 stream 0 was not closed cleanly: CANCEL (err 8)
    error: 5182 octets de corps sont encore attendus
    fetch-pack: unexpected disconnect while reading sideband packet
    fatal: fin de fichier prématurée
    fatal: fetch-pack : sortie d'index de pack invalide
    But surely some people on this platform can tell me what this item is and whether I have a chance to be able to soldier a new one back? Thanks! Best regards, Kristion
    Click image for larger version  Name:	Motherboard.jpg Views:	27 Size:	158.8 KB ID:	3328620 Click image for larger version  Name:	MotherboardCloseUp.jpg Views:	12 Size:	174.2 KB ID:	3328621
  • Answer selected by Kristion at 08-20-2024, 02:51 PM.
    mon2
    • Dec 2019
    • 14713
    See attached.
    Appears to be C7212.
    Click image for larger version  Name:	C7212.png Views:	0 Size:	83.2 KB ID:	3328751
      • 31278
      maybe it's an inductor coil.
      why didnt openboardview install?
      did you contact Paul Daniels?
      • mon2
        • Dec 2019
        • 14713
        See attached.
        • piernov
          • Jan 2016
          • 4439
          • France
          https://github.com/OpenBoardView/OpenBoardView/releases
          • mon2
            • Dec 2019
            • 14713
            Correction - openboardview is by piernov. Paul Daniels' s/w is another tool.
            • Kristion
              • Aug 2024
              • 7
              • France
              Wow, mon2 Thanks heap, you are great! So it is indeed a badcap! 33μF. Do you know where I can find this kind of cap, I mean with this (very small) kind?
              • Kristion
                • Aug 2024
                • 7
                • France
                Thanks piernov it works! This is great!! apt install is way easier than building the thing, thanks!!
                • mon2
                  • Dec 2019
                  • 14713
                  TAJB336K016RNJ KYOCERA AVX | Capacitors | DigiKey
                  • Kristion
                    • Aug 2024
                    • 7
                    • France
                    Great, thanks! I ordered some (it comes by bunch of 5 costing close to nothing). Now I have to soldier that on board!! That will be a first for me. I saw on some videos that people use a thermal paste but actually I don't know where to begin. I am going to dig the Equipment Usage... forum. Thanks heap folks!!
                    • mon2
                      • Dec 2019
                      • 14713
                      You There is a polarity to this capacitor so be sure to review the datasheet and also the placement of the part you are replacing. Confirm that ground pad is mating to the ground pad of this capacitor. YT will also have many videos on capacitor replacement. Suggest to practice on a donor board that you can pickup off EBay. Watch YT videos from Louis Rossmann and also Alex (Northridge Repair).
                      • MikoMiko
                        MacBook Pro A2251 - 820-01949-A not charging
                        by MikoMiko
                        Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
                        03-24-2025, 11:09 AM
                      • envym
                        MacBook Pro 2018 with Activation Lock
                        by envym
                        Hi everyone!
                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                        06-27-2025, 08:54 AM
                      • PITERPENY
                        Macbook A2251 no boot
                        by PITERPENY
                        The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
                        01-05-2025, 03:11 PM
                      • mferna14
                        MacBook Pro A2251 820-01949-A stuck on 5V
                        by mferna14
                        Hi Dear friend., I am working MacBook Pro A2251 Logic board 820-01949-A. The history was that there was slight liquid on the LHS CD3217 & was not powering on at all. No 20v or any amps. I replaced with known good CD3217s & then got the power but its stuck on 5V .18amp. I did power measurements which are below:
                        PPBUS_G3H=12v
                        PP3V3_G3H=3.3v
                        PP3V3_UPC_X_LDO=3.3v
                        PPDCIN_G3H=5v ????
                        PP1V8_SLPS2R=1.8v
                        Do you think the other RHS CD3217 have to be replaced to as they might have gone defective????​
                        11-08-2024, 05:35 PM
                      • Arshad alam4659
                        macbook a2251 no power
                        by Arshad alam4659
                        i have a macbook a2251 820-01949-a 5v stuck with 0.274ma
                        some measured volt
                        PP3V3_G3H_RTC=3.3v
                        PP1V8_SLPS2R=1.8v
                        PPBUS_G3H=12v
                        PP3V3_G3H=3.3v
                        P5VP3V3_VREG3=3.3v
                        PP5V_S5_LDO=0v
                        PP20V_USBC_X_VBUS=0v...
                        10-24-2024, 02:29 AM
