macbook a2251 no power
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    i have a macbook a2251 820-01949-a 5v stuck with 0.274ma
    some measured volt
    PP3V3_G3H_RTC=3.3v
    PP3V3_UPC_X_LDO=3.3v
    PP1V8_SLPS2R=1.8v
    PPBUS_G3H=12v
    PP3V3_G3H=3.3v
    P5VP3V3_VREG3=3.3v
    PP5V_S5_LDO=0v
    PP20V_USBC_X_VBUS=0v
  • MikoMiko
    MacBook Pro A2251 - 820-01949-A not charging
    by MikoMiko
    Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
    03-24-2025, 11:09 AM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • PITERPENY
    Macbook A2251 no boot
    by PITERPENY
    The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
    01-05-2025, 03:11 PM
  • mferna14
    MacBook Pro A2251 820-01949-A stuck on 5V
    by mferna14
    Hi Dear friend., I am working MacBook Pro A2251 Logic board 820-01949-A. The history was that there was slight liquid on the LHS CD3217 & was not powering on at all. No 20v or any amps. I replaced with known good CD3217s & then got the power but its stuck on 5V .18amp. I did power measurements which are below:
    PPBUS_G3H=12v
    PP3V3_G3H=3.3v
    PPDCIN_G3H=5v ????
    PP1V8_SLPS2R=1.8v
    Do you think the other RHS CD3217 have to be replaced to as they might have gone defective????​
    11-08-2024, 05:35 PM
  • pb1911nt
    MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
    by pb1911nt
    Hello forum,
    I'm still relatively new to the world of electrical repairs.
    I have a Macbook here that I can't figure out
    When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
    I removed the logic board and took a few measurements.
    But I can't really figure it out.
    At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
    09-07-2025, 11:35 AM
