MacBook Pro A2251 - 820-01949-A not charging
  • MikoMiko
    • Mar 2025
    Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where the audio jack is located, not going further than 2cm into the logicboard. I took a visual inspection of the board and could not see any blown capacitor, I measured a lot of the caps and none were shorted. When the cable is plugged in I can measure the 12.4V, without the cable none, probably because the battery is empty. I bought a thermal camera and a USB Meter to get more information for the diagnosis. I could measure 3.3v across some places. I will look deeper into the schematic to get an idea of the problem but need to get a second computer for that. Do you guys have an idea where the problem comes from? Which lines should I measure to get a better understanding of what's wrong?
    Due to work I can continue diagnosing it next week, and then I will have access to a microscope and the thermal camera and the meter should have arrived until this point.
    I will update you guys when I find out more.
  • FriedFred
    • May 2024
    • 143
    Maybe the battery itself is bricked.
    • reformatt
      • Feb 2020
      • 1693
      Are you getting 20V negotiated on USB-C and what is the current flow? Check battery flex cable for corrosion etc, SMBUS lines to battery etc. Go to System Report/Power, is battery data reported? Service Recommended etc?
      MAC OS doesn't report charging till about 1 minute after being plugged in, even though battery is charging.
      • tccyo22
        Macbook A2251 820-01949A - 20v not powering on or charging
        by tccyo22
        Hi there, this one has me stumped. Quick back story is this macbook had a very small liquid damage on one side of charge ports which burnt the connector. I've currently got that side of USB ports disconnected and I've replaced the connector and the CD3217 that was stopping the macbook from transitioning to 20v. (It was originally stuck at 5v 0a) and I'm using the other side to diagnose this board.
        I now get 20v and it appears as though the macbook is attempting to boot but it's failing? On connection of usb power I watch the voltage swap from 5v to 20v and sit at 0.1a for 2-3 seconds...
        03-04-2026, 03:34 AM
      • berlincaps
        Macbook Air M1 A2337, no charging and then no backlight
        by berlincaps
        Dear BADCAPS Forum,
        I am happy to have found this place and would love to get some input on my issues with a MacBook Air M1 (A2337).
        A couple of days ago, I was using the MacBook on a low battery, and while running VS Code it shut down due to low battery. I rarely let it reach the point where it turns itself off, and if it does, I usually charge it immediately. This time, however, I left it uncharged until the next evening, and when I plugged it in, nothing happened. I waited until the following day, and still nothing.
        I followed all the recommended troubleshooting...
        01-10-2026, 10:34 AM
      • MICHAEL_2013
        Macbook Pro Core I7 A2251 EMC3348 Help Remove MDM
        by MICHAEL_2013
        Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
        Model A2251 EMC 3348. Serial Number: C02G54CZML85
        Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
        I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
        C02G54CZML84 only works up to Monterey.
        C02G54CZML86 doesn't work (I...
        11-20-2025, 11:18 AM
      • Stephen
        A2251 MacBook Pro 13" Charging issue
        by Stephen
        Hello old friends,
        I have a customer that came in with a A2251 MacBook Pro 13" DFU mode revive works, DFU works, battery is in Normal state checking the computer, however it only charges up to 65% then it stops and charges again and stops and charges again every 5 seconds. It disconnects from the cable (we are using an OEM 61W and OEM cable) question is being that the Battery is in Normal state (Not service recommend or replace now or soon) could this be a faulty board issue or? Would like your expertise, I am leaning towards replacing the battery to see if it persists but before...
        06-28-2024, 02:55 PM
      • drlarsen
        MacBook Air M1 A2337 battery/charging issue
        by drlarsen
        Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
        I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
        On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
        After some hours, the battery status did not improve. Restore via DFU did not help.
        I connected the power adapter to a Kill-a-Watt...
        07-17-2025, 02:35 PM
