help to find the ic number , asus x541na laptop motherboard
  • Dilane
    • Sep 2015
    • 38
    • Srilanka
    • 21841
    Can`t see the IC marking code on that tiny picture. Is the IC part number listed in the boardview https://www.badcaps.net/forum/troubl...atic-boardview
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • rddube
      Scorching hot mosfets on Asus X555Q motherboard - can't find the cause
      by rddube
      I am reading temperatures above 105C (221F) on mosfets PQL8104 and PQL8103 and the board is operating fine until it goes above 105C and then it shuts down. Cpu is ok.
      So can't figure it out. Attached is photo of motherboard, the schematic section showing the culprit mosfets and the whole motherboard schematic. I changed PL8101 thinking it may be bad, same results. I tested out of circuit caps PC8117 and PC8118 and they measure fine.
      So I am at a loss to know what else to check to try and identify the source of the problem
      Any...
      03-08-2024, 08:57 PM
      ASUS P5GC-MX motherboard recap
      by momaka
      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
      So here is what the motherboard looked like with its original caps:
      CPU VRM area up close…...
      01-27-2021, 11:59 PM
    • MakNCheese
      ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
      by MakNCheese
      I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
      Symptoms:
      • Severe lag across the system, including BIOS navigation.
      • Slow boot times and unresponsive performance in Windows.
      • Battery charges very slowly (e.g., ~5% in 2–3 hours).
      • No error messages or BSODs, just extreme sluggishness.
      What I've Tried:
      • Replaced
      06-04-2025, 12:48 AM
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
