Lenovo S145-15IL won,t charge
  • Zippo978
    • 47
    • Italia
    Measured the resistance of the mosfets
    PQ103
    S-D= 0.7 / 0.9
    S-G= 206
    G-D= 1.1
    PQ104
    S-D= 0.5
    S-G= 197
    G-D= 0.5​
    • mon2
      • Dec 2019
      • 14538
      Unable to understand the measurements.
      Post a link to your meter’s user manual in English. There must be a way to force the meter to measure the resistance.
      Resistance measurements will be in ohms.
      Place one meter probe on mosfet pin #1 and other probe on pin #8. This check is the source-drain resistance. Never any power to the board in resistance mode checking.
      Post the measurement and the units of measurement. Ohms, kohms, Megaohms, etc.
      Or take a pic of each measurement of your meter face.
      • Zippo978
        • 47
        • Italia
        Let's see if I can borrow a tester on Monday
        • Zippo978
          • 47
          • Italia
          Repeat the measurements
          PQ103
          SD= 0,7 / 0,9 M
          SG= 206 K
          GD= 1,1 M
          PQ104
          SD= 0,5 M
          SG= 197 K
          GD= 0,5 M
          I hope they go well this time
          • mon2
            • Dec 2019
            • 14538
            PQ103
            SD= 0,7 / 0,9 M
            SG= 206 K
            GD= 1,1 M
            PQ104
            SD= 0,5 M
            SG= 197 K
            GD= 0,5 M​
            These measurements look low for a good mosfet. Consider to flux and remove off the board for additional testing. They may need to be replaced.
            • Zippo978
              • 47
              • Italia
              #26
              Since I have two identical cards inside, which I can use as donors, how much should those values ​​be?
              • mon2
                • Dec 2019
                • 14538
                You can check Google for many of these articles / video tutorials on YT.
                A good mosfet should offer a high resistance of Mohms.
                • Zippo978
                  • 47
                  • Italia
                  #28
                  Ok, thanks.
                  Do I take them apart and do the same measurements?
                  • mon2
                    • Dec 2019
                    • 14538
                    Yes, flux it well -> hot air till the solder melts - be patient and protect other nearby parts with low air pressure. Parts that can melt should be shielded from the heat. Then remove off the board -> allow it to cool and test the mosfet again using the same method.
                    • Zippo978
                      • 47
                      • Italia
                      #30
                      Disassembled and re-measured
                      S-D = 1.1M on both
                      I have no readings on the others​
                      • mon2
                        • Dec 2019
                        • 14538
                        Check post #25 - the measurements in RED are of concern. Test those again.
                        • Zippo978
                          • 47
                          • Italia
                          #32
                          I have no measurements on the disassembled mosfets.
                          On the motherboard without mosfet between Source and Gate I have the same values as in post 25
                          • Zippo978
                            • 47
                            • Italia
                            #33
                            Sorry for my ignorance, but as I was saying I just started, I shouldn't find 9V on pin 5678 of PQ102, I understand this from the diagram.
                            • mon2
                              • Dec 2019
                              • 14538
                              Did you say that you have a working unit of the same model available for measurements?
                              • Zippo978
                                • 47
                                • Italia
                                #35
                                No, only a donor board from which I have already taken some parts is not working, such as the mosfets on the primary and the bios chip
                                • mon2
                                  • Dec 2019
                                  • 14538
                                  Measure the voltage to ground of ACOK (pin # 5) on the charger IC (PU100).
                                  • Zippo978
                                    • 47
                                    • Italia
                                    #37
                                    Voltage to ground of pin 5 of PU100 2.5V.
                                    Can you tell me what Batt+ and V9B+ mean?​
                                    • mon2
                                      • Dec 2019
                                      • 14538
                                      BATT+ is the junction where the battery is used as the power source. In this case, the power adapter's DCin mosfets will be OFF, the charger mosfets for the battery @ PQ103 & PQ104 will be OFF. The battery flow through mosfet @ PQ102 will be ON. This battery voltage is ~9 volts and is ample to power the logic board.
                                      Respectively, the V9B+ is the main power rail used to power the logic board. If the main power adapter is applied, then the ~19 volts will travel through the power path, through the enabled 2 x DCin mosfets to supply the ~19 volts onto the main power rail. In this case, since the power adapter is mated to the logic board, the battery charger mosfets will toggle on/off to regulate the proper battery charge voltage using mosfets PQ103 & PQ104 to a safe voltage. The current sense resistor in this battery charge circuit is monitored for safety.
                                      The main battery mosfet @ PQ102 will be OFF in this case since the main power adapter is powering the logic board.
                                      • Zippo978
                                        • 47
                                        • Italia
                                        #39
                                        Ok thanks, that's what I thought, I needed confirmation.
                                        What can you tell me about it?
                                        With power supply and without battery, voltage to ground of pin 5 of the PU100 2.5V.​
                                        • mon2
                                          • Dec 2019
                                          • 14538
                                          See attached. Confirm if you have the 2 resistors onboard with a high side and a low side to lower the REGN voltage.
                                          Confirm if you have ~6 volts on one leg of resistor PR112.
                                          That is, with a 6 volt input, with PR112 & PR111, the ACOK voltage will be divided down.
                                          Can you confirm the resistance of PR111? PR112? Remove all power / remove the battery. Measure the resistance across each resistor to measure.
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                            09-14-2023, 11:10 PM
                                          • razenxd
                                            How can I charge that battery pack?
                                            by razenxd
                                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                            Now, I have noticed a few things.
                                            The "dead" battery, while connected to charger and NOT Charging will...
                                            12-05-2024, 06:11 AM
                                          • ruletero
                                            Acer a515-43 low battery charge voltage
                                            by ruletero
                                            Hi
                                            Acer A515-43
                                            LA-H801P
                                            Fail: Does not charge battery, has low voltaje on connector.
                                            Laptop didn't want to turn on, only charge led blinked.
                                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                            10-24-2022, 02:31 PM
                                          • Patriarxis
                                            Lenovo ideapas s145-15API dosent charge battery
                                            by Patriarxis
                                            Hello
                                            I have a lenovo idaepad s145-15API anf it dosent charge the battrery.
                                            When i use it without the battery it works fine with the charger
                                            when i connect the battery stop to take power from the charger and works only with the battery....
                                            02-25-2025, 05:45 AM
                                          • code share
                                            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                            by code share
                                            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                            Here's what I've tried so far:
                                            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                            • Booted successfully on AC power only with the battery disconnected
                                            • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                            • Battery
                                            04-21-2025, 12:50 PM
