Lenovo ideapas s145-15API dosent charge battery
  • Patriarxis
    • 19
    • Greece
    Hello
    I have a lenovo idaepad s145-15API anf it dosent charge the battrery.
    When i use it without the battery it works fine with the charger
    when i connect the battery stop to take power from the charger and works only with the battery.
  • mon2
    • 14520
    https://www.badcaps.net/forum/troubl...arging-circuit
    • agswireless
      Lenovo Y50-70 (LA-B11P) no charge problem
      by agswireless
      ok so I have this Lenovo y50-70 touch that has a no charge problem, maybe someone can point me in the right Direction since I cannot find a schematic for Borderview
      what are you guys opinion on where to start to check why its not charging?
      Back story:
      I bought this with a bad charging port, previous owner stated it charge fine but his kid kicked the cord and rip the plug and port out.
      so I ordered a new one, but when I was replacing the plug the open wire touch and made a spark because I completely forgot to unplug the battery.
      so I went a head changed out...
      01-30-2024, 01:39 AM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Oyama65
      lenovo yoga 3.14 (80jh) laptop and will not power on or charge
      by Oyama65
      Mainboard model: BTUU1 NM-A381 REV: 1.0
      i have an lenovo yoga 3.14 (80jh) laptop and will not power on or charge, measured the battery voltage 0.00v dead flat.
      i managed to charged the battery, placed the battery back into the laptop and powered up.
      checked for shorts, checked mosfets, fuses and caps around battery and input not see anything, ive missed something.
      i wasn't getting negotiating voltage 19v only 5v. so i replaced the pu101 (BQ24715RGRR), once replaced i was getting negotiating voltage 19v but blinking white light 3sec...
      09-12-2024, 05:30 AM
    • Zippo978
      Lenovo S145-15IL won,t charge
      by Zippo978
      I have a Lenovo motherboard Lenovo S145-15IL, NM-C711.
      Initially it wouldn't turn on, I replaced the PQ100 and PQ101 mosfets and the BIOS chip and it works perfectly except charging the battery which says it's connected and charging but the percentage doesn't go up. In pins 1 and 2 of the JBATT5201 I find 7.8V, and at the input of the PQ102 and 103 mosfets I have 19V.
      I don't understand why the battery doesn't charge, thanks in advance for your help.
      P:S: Thinking it was the battery I replaced it with a new one and updated the BIOS and Firmware....
      07-05-2024, 03:41 AM
    • AleX.dans.les.nuages
      Lenovo Ideapad Gaming 3 15ACH6 doesn't charge
      by AleX.dans.les.nuages
      Hello from France
      My daughter spill some water on her laptop... Lenovo Ideapad Gaming 3 15ACH6, and she doesn't seen anything wrong after just remove the water with towel.
      Then, later the laptop won't start anymore.
      I've made a basic troubleshoot with my own laptop (same series)
      So, the computer battery is totaly out. With my battery, the computer works !
      But, with PSU connected, the latptop detect the power.. the harware led white is on, the amber one too and on the screen there is a 'batt charging' message.
      But...
      04-13-2025, 12:38 PM
