Lenovo S145-15IL won,t charge
  • Zippo978
    • 48
    • Italia
    I have a Lenovo motherboard Lenovo S145-15IL, NM-C711.
    Initially it wouldn't turn on, I replaced the PQ100 and PQ101 mosfets and the BIOS chip and it works perfectly except charging the battery which says it's connected and charging but the percentage doesn't go up. In pins 1 and 2 of the JBATT5201 I find 7.8V, and at the input of the PQ102 and 103 mosfets I have 19V.
    I don't understand why the battery doesn't charge, thanks in advance for your help.
    P:S: Thinking it was the battery I replaced it with a new one and updated the BIOS and Firmware.
    [MOD EDIT] Link to schematic https://www.badcaps.net/forum/troubl...atic-boardview
  • mon2
    • Dec 2019
    • 14685
    Share each voltage on the battery connector. We wish to confirm the smbus voltages for the sda / scl lines. Every such battery pack counts a bms (battery management system) that communicates over smbus to the charger IC.
    Be sure the batteries and the power adapter are compatible for this unit. If the power adapter is under rated, the battery will not charge.
    • Zippo978
      • 48
      • Italia
      The charger is original Lenovo and has 20.42V output
      The battery is compatible, I had already replaced the original with the same model and it worked perfectly.
      The voltages on the battery connector are
      Pin 1/2 - 7.82V (VBAT)
      Pin 3 - ranges from 3.25V to 3.29V (EC_SMCA)
      Pin 4 - ranges from 3.25V to 3.29V (EC_SMDA)
      Pin 5 - 1.26V (N17245833)
      Pin 6 - N/C
      Pin 7/8/9/10 - GND
      If I put the original battery it says 100% but that's not true.​
      • mon2
        • Dec 2019
        • 14685
        Remove all power. Meter in lowest resistance mode.
        Measure the resistance directly at the charger IC pin # 11 to the actual battery connector (disconnect the battery during this measurement). Confirm there is a full path from the charger IC to the battery connector. What is the resistance?
        Repeat for pin # 12 in the same way. What is the resistance?
        Confirming that the SMBUS lines have a valid path from start/finish.
        The charger IC is 'assuming' the battery capacity because it is reading 'FFh' default values.
        • Zippo978
          • 48
          • Italia
          If I understand correctly, I have to measure from pin 11 and 12 of the PU100 to pin 3 and 4 of the battery connector, right?
          From the battery Pin 3 - pin 11 4.49k pin 3 - pin 12 0.10k
          Pin 4 - pin 11 0.10k and pin 4 - pin 12 4.49k​
          • mon2
            • Dec 2019
            • 14685
            These measurements are ok. This confirms the PCB traces are ok from start to finish with 100 ohms of resistance as showing in the schematics.
            Locate pin # 5 on the battery connector and connect it to ground.
            This is the BATPRES# signal and is active low (denoted with the '#' suffix). If this line is a logic LOW = '0' then the battery is present. Then test again. Post your updates.
            • Zippo978
              • 48
              • Italia
              So with the battery inserted I measure from pin 5 to ground and redo the first measurements right?
              Sorry but I just started.​
              • mon2
                • Dec 2019
                • 14685
                Also interested in the resistance reading (measure directly at the charge IC) of pins 19 & 20. One probe on 19, other on pin 20 - no power / no battery during this measurement. We are checking the full path resistance of the current sense loop circuit for the battery charge circuit. This measurement should be ~20 ohms if all is ok.
                • mon2
                  • Dec 2019
                  • 14685
                  On post #7 - no. Take a piece of wire and connect one side to ground - the other side of the wire to pin # 5 of the battery connector. We are forcing this pin to ge at 0 volts which is ideal to force the charger to know there is a battery connected. Then test again. The wire must remain in place as noted to ground.
                  • Zippo978
                    • 48
                    • Italia
                    From the battery Pin 3 - pin 11 4.44k pin 3 - pin 12 0.98k
                    Pin 4 - pin 11 0.09k and pin 4 - pin 12 4.44k​
                    • Zippo978
                      • 48
                      • Italia
                      Click image for larger version  Name:	srp_srn.png Views:	0 Size:	201.1 KB ID:	3303126
                      20Ohm
                      • mon2
                        • Dec 2019
                        • 14685
                        Post a pic of your meter screen to confirm the units of measurement. Also touch your meter probes together while in the resistance mode. What is the measurement?
                        See attached on how to short the wire on pin # 5 of the battery connector = BATTPRES# signal.
                        • Zippo978
                          • 48
                          • Italia
                          Sì, i fili sono stati tagliati, il connettore è stato preso da una vecchia batteria danneggiata e invece di saldare ho legato insieme un filo di terra e il filo del pin 5
                          I have a automatic tester
                          • mon2
                            • Dec 2019
                            • 14685
                            Ok. With the power adapter and battery connected -> carefully measure the voltage to ground at inductor PL100. This is the battery charge voltage.
                            • Zippo978
                              • 48
                              • Italia
                              Ok, 7.8V
                              • mon2
                                • Dec 2019
                                • 14685
                                What are the battery pack markings for the voltage?
                                What is the voltage to ground of ILIM pin # 21 on the charger IC ? This pin defines the battery charge current.
                                • Zippo978
                                  • 48
                                  • Italia
                                  ILIM 1,182 V
                                  Bbatteria originale
                                  Compèatible
                                  • mon2
                                    • Dec 2019
                                    • 14685
                                    While the battery is not connected to your board - what is the voltage? Measure between the RED and BLACK wires on your battery pack. It appears that the charger IC is not even producing the charge voltage. The voltate you are measuring is from the pre-charged battery itself. Confirm it.
                                    • Zippo978
                                      • 48
                                      • Italia
                                      On the battery I have 7.3V
                                      I have to go now, we will continue tomorrow, thank you for what you have done so far
                                      • mon2
                                        • Dec 2019
                                        • 14685
                                        Ok. It appears that the high and low side mosfets are not creating the charge voltage to charge the battery pack.
                                        Tomorrow, test PQ103 and PQ104 by their resistance. Remove the battery & power adapter.
                                        Measure the resistance across:
                                        source (1-2-3) & drain (5-6-7-8)
                                        source (1-2-3) & gate (4)
                                        gate (4) & drain (5-6-7-8)
                                        Interested to know each resistance measurement. Do this for both mosfets. If either mosfet is defective, the battery will not charge.
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Patriarxis
                                          Lenovo ideapas s145-15API dosent charge battery
                                          by Patriarxis
                                          Hello
                                          I have a lenovo idaepad s145-15API anf it dosent charge the battrery.
                                          When i use it without the battery it works fine with the charger
                                          when i connect the battery stop to take power from the charger and works only with the battery....
                                          02-25-2025, 05:45 AM
                                        • code share
                                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                          by code share
                                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                          Here's what I've tried so far:
                                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                          • Booted successfully on AC power only with the battery disconnected
                                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                          • Battery
                                          04-21-2025, 12:50 PM
