Acer 6920g Battery voltage
  • artois7
    • Mar 2011
    • 159
    Is the correct battery for the 6920g 10.8v or 11.1v? I have both variants here, and both charge/work.
    Dan
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    Re: Acer 6920g Battery voltage
    so you can use any one
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • survivalbloke
      Acer Predator Helios 300 - will not power up if battery is CONNECTED
      by survivalbloke
      This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
      06-25-2025, 12:20 PM
    • alderick
      Acer E5-575-39FE no voltage on battery
      by alderick
      Hello guys,
      Laptop have been dropped, broken screen and battery had no voltage on connector.
      I replaced the screen and it's ok, but still no voltage on battery connector, 16.91V on cells, which is fine for 4cells battery.
      I ordered a brand new battery from Acer, same thing, no voltage on it's connector.
      Is this a MB issue?
      I did some measurement on the bq24780s, but since there is no voltage on battery i'm not sure it's any help?
      Thank for reading.
      EDIT :
      1 ACN 19
      2 ACP 19
      3 CMSRC...
      11-30-2020, 04:40 AM
