Acer E5-575-39FE no voltage on battery
  • alderick
    • Jun 2015
    • 74
    • france
    Hello guys,
    Laptop have been dropped, broken screen and battery had no voltage on connector.
    I replaced the screen and it's ok, but still no voltage on battery connector, 16.91V on cells, which is fine for 4cells battery.
    I ordered a brand new battery from Acer, same thing, no voltage on it's connector.
    Is this a MB issue?
    I did some measurement on the bq24780s, but since there is no voltage on battery i'm not sure it's any help?
    Thank for reading.
    EDIT :
    1 ACN 19
    2 ACP 19
    3 CMSRC 18,98
    4 ACDRV 24,6
    5 ACOK 3
    6 ACDET 2,58
    7 IADP 0
    8 IDCHG 0
    9 PMON 0
    10 PROCHOT 0
    11 SDA 3,27
    12 SCL 3,27
    13 CMPIN 0
    14 CMPOUT 1,39
    15 BATPRES 0
    16 TB_STAT 3,41
    17 BATSRC 0,24
    18 BATDRV 0,27
    19 SRN 0,24
    20 SRP 0,24
    21 ILIM 0,81
    22 GND 0
    23 LODRV 0
    24 REGN 6,06
    25 BTST 5,72
    26 HIDRV 0,24
    27 PHASE 0,24
    28 VCC 19
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Acer E5-575-39FE no voltage on battery
    Did you check battery disable switch?
    OpenBoardView โ€” https://github.com/OpenBoardView/OpenBoardView
    • alderick
      • Jun 2015
      • 74
      • france
      No, can you tell me how please?
      If you mean the switch under the laptop we can reach by a small hole, I did check and it's working fine. 0.2 ohm when pressing and open circuit when release.
      • alderick
        • Jun 2015
        • 74
        • france
        I'm so stupid, didn't even see the big switch next to the other one, when I press it, battery start deliver current and laptop is working on battery.
        Thanks, case closed.
        • ruletero
          Acer a515-43 low battery charge voltage
          by ruletero
          Hi
          Acer A515-43
          LA-H801P
          Fail: Does not charge battery, has low voltaje on connector.
          Laptop didn't want to turn on, only charge led blinked.
          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
          10-24-2022, 02:31 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • survivalbloke
          Acer Predator Helios 300 - will not power up if battery is CONNECTED
          by survivalbloke
          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
          06-25-2025, 12:20 PM
        • abrahim110
          [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
          by abrahim110
          ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
          I have an Acer Aspire 5 A517-52G-53NB laptop.
          The onboard (soldered) RAM was faulty, so I physically removed the chip.
          I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
          โœ… System status:
          • BIOS mod is done (SPD removed)
          • Laptop boots to Windows normally
          • RAM is detected and stable
          โŒ Problem:
          The battery is not charging:
          • Power adapter
          08-06-2025, 06:15 AM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
