A2338 battery don't charge
This topic has been answered.
+ More Options
Posts
  • zippylin
    • Nov 2020
    • 15
    • us
    model: A2338, I got a problem with battery don't charge, the BGATE(B3) of U5200 is 12V with battery or without battery. I don't know why, have someone provide the idea to solve it? thank you
  • Answer selected by zippylin at 07-27-2024, 09:34 PM.
    zippylin
    • Nov 2020
    • 15
    • us
    After change a new battery, the don't charge problem is solved. I guess the original battery may be lock due to some reason, even I charge the cell by power supply directly
    and the cell voltage already up to 11.8V.
    • mon2
      • 14445
      Measure the voltage to ground of each pin on the battery connector @ J5151.
      Post the measurements.
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        tried SMC reset ?
        • zippylin
          • Nov 2020
          • 15
          • us
          J5151:
          pin 2 & 3 is 3.259V
          pin 7 is 0V
          any problem for this voltage measured result? thank you
          • zippylin
            • Nov 2020
            • 15
            • us
            this's measure voltage on U5200
            • zippylin
              • Nov 2020
              • 15
              • us
              Originally posted by PITERPENY
              tried SMC reset ?
              I will try it later when I get another component and fix it on connector.
              • mon2
                • 14445
                J5151 voltage check is ok for the SMBUS lines. They are not shorted.
                Remove all power. Meter in resistance mode. Check the battery mosfet @ Q5265.
                Measure the resistance across:
                source (1-2-3) & drain (5-6-7-8) ; select any pin from each group
                source (1-2-3) & gate (4)
                gate (4) & drain (5-6-7-8)
                Post each measurement. Checking for a low resistance which usually means the mosfet is defective.
                • zippylin
                  • Nov 2020
                  • 15
                  • us
                  The D to S: 1.619M ohm
                  G to S: 3.7M ohm
                  G to D: 4.97M ohm
                  thank you
                  • zippylin
                    • Nov 2020
                    • 15
                    • us
                    • techfreak9356
                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                      by techfreak9356
                      09-14-2023, 11:10 PM
                    • razenxd
                      How can I charge that battery pack?
                      by razenxd
                      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                      Now, I have noticed a few things.
                      The "dead" battery, while connected to charger and NOT Charging will...
                      12-05-2024, 06:11 AM
                    • ruletero
                      Acer a515-43 low battery charge voltage
                      by ruletero
                      Hi
                      Acer A515-43
                      LA-H801P
                      Fail: Does not charge battery, has low voltaje on connector.
                      Laptop didn't want to turn on, only charge led blinked.
                      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                      10-24-2022, 02:31 PM
                    • Klevjetack
                      Charge a L19D3PDA battery externally from the laptop
                      by Klevjetack
                      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                      03-05-2024, 07:26 AM
                    • dclass-pro
                      Latitude 3301 not charge battery
                      by dclass-pro
                      Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                      I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                      I noticed 2 things:
                      1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                      2) if I try to turn it on without the battery...
                      05-06-2025, 06:19 AM
