Macbook 820-3330 no power or charging
  • johnisburt
    • Apr 2023
    • 13
    Hi guys, how are you all?
    I have a MacBook 820-3330 with no power and need a little help please.
    I have the original charger that supplies 16v but doesn't light up at all. I also have a USB C charger and converter that does light up and provides 19v.
    Both give me a 12v on board and i have 3.3v.
    I have 5 volt but its at 4.7v.
    I have 1 voltage that isnt present but dont know if this comes after power on, this is q7220 pins 6,7,8 0v, doesnt seem to have any switching voltages going in from u7201.
    I will give you some readings that I have and we can go from there.
    Thanks in advance.
    F9700 12v both sides
    BKL_EN is 0v (not sure again if present before power on)
    F7040/F7041 good
    U6900 3.3 in and out
    This is all i can think of atm.
    Thank you John​
  • mon2
    • 14663
    Someone is pulling the 5 volt line down. Remove all power. Check the resistance to ground of the 5v rail that is reading at 4v7.
    • johnisburt
      • Apr 2023
      • 13
      Will check in morning, thank you
      • johnisburt
        • Apr 2023
        • 13
        G3hot 5.5v rail is 122k ohm
        • johnisburt
          • Apr 2023
          • 13
          And voltage is 4.99 today but still no power or fan spin
          • kevingill
            • Jun 2013
            • 152
            • England
            Is the problem with PP5V_S3_REG or PP5V5_CHGR_VDDP?
            Are you using an 85W charger BTW?
            • johnisburt
              • Apr 2023
              • 13
              Charger is 60w
              ive actually not checked pp5v_s3 (can’t see reg) but this is 0v
              pp5v5 is at 4.99 so close is .6 in tolerance?
              • johnisburt
                • Apr 2023
                • 13
                Small update, q7260 has burnt out when I plugged in the battery so either something on the battery circuit has caused it or this was faulty or maybe even u7201 I don’t know. Have to call this done for now.
