Acer 5715Z 1.8V is dead
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    System switches on 1.8V rail shows 0.50V and no +CPU_CORE voltage at PL7 &PL8
    Replaced PU8 +1.5VSP/+1.8VP generator but no change. There is no short at 1.8V rail and to the ground it shows 140ohms.
    Pls and ideas ?
  • dj_ricoh
    • 2073
    • uk
    Re: Acer 5715Z 1.8V is dead
    try i soft reflow on the chipset
    • tomodachi
      • Apr 2012
      • 610
      • Turkey
      Did a proper reflow, didn't work :/
      • Francisco.s
        • 686
        • Spain
        Pls and ideas ?
        Check value of PR127.
        Also check VR_ON signal.
        • tomodachi
          • Apr 2012
          • 610
          • Turkey
          I m home at the moment. I 'll check tomorrow and post here, many thanks btw
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • bripoll
            Acer Veriton N4670GT Dead
            by bripoll
            Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
            The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
            It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
            I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
            I have programmed it, but it still won't start, it is dead
            Before programming...
            11-23-2023, 02:56 PM
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
            09-06-2024, 05:27 AM
