How to use EV2400 clone battery programer?
+ More Options
Posts
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3576
    • slovakia
    Hello.
    As someone suggest i bought this EV2400 clone battery programmer. Now i have one battery that need to check, but i cannot find topic with guide.
    So what program should i use and how to check that battery?
  • mon2
    • Dec 2019
    • 13974
    EV2400 is originally a tool by Texas Instruments. Download the program from their website.
    • mon2
      • Dec 2019
      • 13974
      https://www.bravabatteries.com/guide...aptop-battery/
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3576
        • slovakia
        thanks mate. thats all i need to know.
        i must use some ev2400 compatibility software so it wont give error of not found ev2300
        • mon2
          • Dec 2019
          • 13974
          There are 2 different models from TI. EV2300 and the newer EV2400.
          For your EV2400 or clone, I believe you want this application:
          https://dr-download.ti.com/software-...00/sluc291.zip
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3576
            • slovakia
            guys i still cannot connect to battery gauge. still no comunication.
            i use EV2400 with battery management studio with BQ40z50R2 in battery with SDA/SCL, but still no comunicatios?
            any hint?
            • anhbanxoi
              • Sep 2021
              • 171
              • VN
              Take a photo of how you connect the battery with EV2400. But even if you can established a communication with the battery, you will need a password to unseal the battery before modifying any parameters.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • ferah831208
                Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                by ferah831208
                Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                03-18-2025, 01:18 AM
