How to use EV2400 clone battery programer?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3634
    • slovakia
    Hello.
    As someone suggest i bought this EV2400 clone battery programmer. Now i have one battery that need to check, but i cannot find topic with guide.
    So what program should i use and how to check that battery?
  • mon2
    • 14760
    EV2400 is originally a tool by Texas Instruments. Download the program from their website.
    • mon2
      • 14760
      https://www.bravabatteries.com/guide...aptop-battery/
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3634
        • slovakia
        thanks mate. thats all i need to know.
        i must use some ev2400 compatibility software so it wont give error of not found ev2300
        • mon2
          • 14760
          There are 2 different models from TI. EV2300 and the newer EV2400.
          For your EV2400 or clone, I believe you want this application:
          https://dr-download.ti.com/software-...00/sluc291.zip
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3634
            • slovakia
            guys i still cannot connect to battery gauge. still no comunication.
            i use EV2400 with battery management studio with BQ40z50R2 in battery with SDA/SCL, but still no comunicatios?
            any hint?
            • anhbanxoi
              • Sep 2021
              • 180
              • VN
              Take a photo of how you connect the battery with EV2400. But even if you can established a communication with the battery, you will need a password to unseal the battery before modifying any parameters.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • mkdj
                by mkdj
                Mark and model: ASUS X571
                Tests already made:
                - I have removed...
                07-14-2025, 09:16 AM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                09-14-2023, 11:10 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • ferah831208
                by ferah831208
                03-18-2025, 01:18 AM
