Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
  • johnbeton
    • Jun 2021
    • 95
    • Belgium
    I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
    Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
    This is what I measure so far:
    Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
    PPBUS_G3H = 0,79v
    PPBUS_HS_CPU = 0,79v
    PPBUS_HS_OTH5V = 0,79v
    PPBUS_HS_OTH3V3 = 0,79v
    PPBUS_S4_HS_TPAD = 0,79v
    PPDCIN_G3H = 20,02v
    PP3V3_G3H = 3,42v
    PP3V3_G3H_SMC_ISNS = 3,42v
    PP3V0_G3H = 0,37v
    PPVCC_S0_CPU = 0v
    PP5V_S5 = 1,07v
    PP5V_S4 = 0v
    PP5V_S4SW = 0v
    PP5V_S4SW_ISNS = 0v
    PP5V_S0 = 0v
    PP5V_S0_KBD = 0v
    PP3V3_S5 = 0v
    PP3V3_SUS = 0v
    PP3V3_S4 = 0v
    PP3V3_S0 = 0v​
  • mon2
    • Dec 2019
    • 14781
    Flux and remove F7000. Do not lose the fuse.
    Then check the resistance to ground again using the PCB pads for F7000. Which side is with the low resistance? Producer side (ISL) or the consumer / downstream side ?
    • reformatt
      • Feb 2020
      • 1544
      I'd try first disconnecting everything external to the board, like keyboard and trackpad, then recheck your PPBUS_G3H resistance to ground. A bad trackpad can cause this, especially if it's liquid damaged.
      I've also managed to knock some components off the board one time when I was being impatient refitting it to the chassis and dragging out some of the connectors that were caught underneath. Tip: Use sticky tape to hold these cables back when you are fitting the board!
      • johnbeton
        • Jun 2021
        • 95
        • Belgium
        I removed F7000 and the low resistance is on side of pin 2 PPBUS_G3H
        Can I inject voltage on this pin to search for short ?
        PS everything is disconnected and the board is disassembled.
        • johnbeton
          • Jun 2021
          • 95
          • Belgium
          I injected 1v 3A on pin 2 of F7000 but the system only draws 0.02 amps.
          What would a normal resistance to ground be on F7000 pin 2 with fuse removed ?
          • mon2
            • Dec 2019
            • 14781
            With no power. Meter in red mode. Measure the resistance to ground of each pin on the battery connector. Checking if the smbus lines are defective.
            • johnbeton
              • Jun 2021
              • 95
              • Belgium
              - is 0,01Ohms
              + is NC
              • mon2
                • Dec 2019
                • 14781
                Need the vitals on the other pins of this battery connector. We are investigating specifically the pin # 2 and # 3 details which are the communicaton lines to the logic board and also linked to the PPBUS_G3H controller.
                • johnbeton
                  • Jun 2021
                  • 95
                  • Belgium
                  pin1 = 3,1 Ohm
                  pin2 = 10,2 KOhm
                  pin3 and 4 = variable from 35 KOhm - 125 KOmh (keeps going up and down)
                  pin 5 - 8 = 1,2 Ohm
                  • mon2
                    • Dec 2019
                    • 14781
                    What is the voltage to ground on F7000 pcb pad (ISL / producer side) with the fuse removed? Use only the power adapter.
                    • johnbeton
                      • Jun 2021
                      • 95
                      • Belgium
                      I'm sorry, which side is ISL / Producer side ?
                      Pin1 = 13.08v
                      Pin2 = 0v
                      • mon2
                        • Dec 2019
                        • 14781
                        Pin1 = 13.08v
                        Pin # 1 on the removed fuse. Now you have a proper PPBUS_G3H voltage to ground. This confirms that the producer side = ISL9239 is working ok. The ISL9239 is the buck / boost regulator that accepts the 20V from the external power adapter and converts this to a lower voltage needed to power the logic board.
                        Respectively, the fault remains on the downstream or consumer side of the F7000 fuse, pin # 2. With a low resistance to ground on pin # 2, the ISL9239 is able to sense this heavy load and powers down the PPBUS_G3H rail.
                        With no power to the board, what is the resistance to ground again on pin # 2 of this removed fuse (F7000)?
                        • johnbeton
                          • Jun 2021
                          • 95
                          • Belgium
                          at this point 119 omh
                          • mon2
                            • Dec 2019
                            • 14781
                            Remove all power. Suggest to measure the resistance to ground of each inductor. Searching for any inductor that may be close to this value of ~119 ohms. Post all suspects. If and when found, then place one meter probe onto F7000, pin # 2 (the downstream side) -> other meter probe onto the inductor that shows a similar resistance.
                            • johnbeton
                              • Jun 2021
                              • 95
                              • Belgium
                              L8050 has the exact same resistance to ground. (other inductors have different values).
                              Resistance between F7000 pin 2 and L8050 is 1,8 Ohm.
                              Could U8050 be the suspect ?
                              • mon2
                                • Dec 2019
                                • 14781
                                Still working on my beauty sleep so do not have the schematics up at this time. This can be trouble as this usually implies that the high side mosfet that is on this found inductor is leaky. That is, if leaky, then the high voltage of ppbus_g3h has travelled onto the low voltage rail created by L8050.
                                Locate all high side mosfets on L8050. Check their resistance across:
                                source and drain
                                source and gate
                                gate and drain
                                Suggest to flux and remove the mosfet to test in the same way when the mosfet is on your table. The measurements should be high K ohms or more if not defective. Replace if lower resistance. Test again by as noted, often means the low voltage parts on this rail have been spiked by the high voltage leak.
                                • johnbeton
                                  • Jun 2021
                                  • 95
                                  • Belgium
                                  ok, I will do so while you have your sleep :-)
                                  • johnbeton
                                    • Jun 2021
                                    • 95
                                    • Belgium
                                    I removed U8050: measured on the mosfet on table:
                                    I have a 2 Ohm resistance from pin 3 to pin 9 (switching probes is same resistance)
                                    And 1.6 Ohm resistance from pin 6 + 7 + 8 to pin 9
                                    With U8050 removed, there is no continuity from F7000 pin 2 to L8050.
                                    With power to the board I now have 13.08V on both sides of F7000.
                                    So I think U8050 is bad.
                                    • mon2
                                      • Dec 2019
                                      • 14781
                                      Yes. Replace this part and test again. The transient that nuked U8050 may have caused additional damage. TBD.
                                      • johnbeton
                                        • Jun 2021
                                        • 95
                                        • Belgium
                                        I replaced the U8050 and PPBUS_G3H stays 13.08v, I have 13.08v coming in on pins 1 + 2 on U8050, but no output.
                                        My probes of my multimeter are not small enough to measure pin 3 and 4 on U8050 without touching other parts.
                                        Pin 5 to 8 are 0v.
                                        I'm not a pro in reading schematics, but if I'm right, U7800 is switching the gates on U8050.
                                        • gabrielA7
                                          Macbook pro A1706 / Backlight flex cable compatibility
                                          by gabrielA7
                                          Hey guys!!
                                          I’ve got a question here!
                                          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                          Here’s what the bot told me:
                                          I said to him: “I’m going to install the 821-01229-A.”
                                          ChatGPT replied:
                                          Understood — but before you solder or install the 821-01229-A,
                                          11-11-2025, 03:26 PM
                                        • Danielreinaa
                                          HELP need password bios Macbook A1706
                                          by Danielreinaa
                                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                          09-07-2024, 03:47 PM
                                        • capon5153
                                          Macbook A1706 works perfectly but no data on USB C
                                          by capon5153
                                          hello,
                                          so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                          i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                          06-22-2025, 09:42 AM
                                        • B2L_Repairs
                                          Macbook A1706 touchpad and keyboard not working. Please help
                                          by B2L_Repairs
                                          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                          10-09-2023, 04:56 AM
                                        • obelix24
                                          A1706 - Macbook pro - one USB-C port only 20V 0A
                                          by obelix24
                                          I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                                          I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                                          There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                                          There were some broken pads under CD3215 but i've recreated them.
                                          What should be...
                                          05-22-2024, 08:04 AM
