Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
  • johnbeton
    • Jun 2021
    • 95
    • Belgium
    OK, my bad, up on closer inspection I noticed the U8050 wasn't fully seated. With more flux and more heat I reflowed U8050.
    Macbook is now back alive ☺☺
    Thank you very much mon2 for your guidance
    • gabrielA7
      Macbook pro A1706 / Backlight flex cable compatibility
      by gabrielA7
      Hey guys!!
      I’ve got a question here!
      I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
      Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
      Here’s what the bot told me:
      I said to him: “I’m going to install the 821-01229-A.”
      ChatGPT replied:
      Understood — but before you solder or install the 821-01229-A,
      11-11-2025, 03:26 PM
    • Danielreinaa
      HELP need password bios Macbook A1706
      by Danielreinaa
      Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
      Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
      Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
      gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
      Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
      09-07-2024, 03:47 PM
    • capon5153
      Macbook A1706 works perfectly but no data on USB C
      by capon5153
      hello,
      so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
      i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
      06-22-2025, 09:42 AM
    • B2L_Repairs
      Macbook A1706 touchpad and keyboard not working. Please help
      by B2L_Repairs
      Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
      10-09-2023, 04:56 AM
    • obelix24
      A1706 - Macbook pro - one USB-C port only 20V 0A
      by obelix24
      I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
      I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
      There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
      There were some broken pads under CD3215 but i've recreated them.
      What should be...
      05-22-2024, 08:04 AM
