aspire 4736z power off after 5sec
  • nazrul145
    • Jan 2014
    • 335
    • BD
    aspire 4736z power off after 5sec. it has nec token. i have changed it but same problem. i reflash bios. again same. sio rsm reset and s5 voltage ok. pls anyone help me what to do.
  • spleenharvester
    • Mar 2010
    • 902
    Re: aspire 4736z power off after 5sec
    Photos of the Tokin repair? Have you checked for continuity between the +ve and -ve points? A short in this location can give the symptoms you described.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • nazrul145
      • Jan 2014
      • 335
      • BD
      no short found on it.
      • spleenharvester
        • Mar 2010
        • 902
        Check your vcore voltage and try a different CPU.
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          have you replaced with same tokin or you used tantalum capacitors? If so how many pieces have you soldered? just curious.....
          • sasser
            • Dec 2012
            • 364
            • Malaysia
            check your tantalum soldered. sometimes not good contct or many flux on there. clean with brush
            • alihomee
              • Dec 2012
              • 1575
              • malaysia
              this is common with this model i also repaired a lot of units by replacing with 4 caps but this auto shutdown problem is very hard to solve i still can not find any solution if any body have something to shere please post hear............thanks
              • nazrul145
                • Jan 2014
                • 335
                • BD
                330*4 pcs solderd.
                • nazrul145
                  • Jan 2014
                  • 335
                  • BD
                  my problem is with and without cpu its shutdown.
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    what your vcore voltage ?
                    • nazrul145
                      • Jan 2014
                      • 335
                      • BD
                      suddenly the laptop is ok. in morning i check vcore again and i notiched that it is not turn off. and display is come. thanks everybody for suggest me.
                      • alihomee
                        • Dec 2012
                        • 1575
                        • malaysia
                        so how u done this
                        • dj_ricoh
                          • 2073
                          i think the caps was the problem but i`m 95% the problem its not all gone.
                          i`ll suggest to search all the caps .
                          • lezsimply
                            The Wanderer
                            • 645
                            • Philippines
                            maybe he added more caps. it usually happens to me, if does not work on 4 I add 2 more
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • Bonaventure Vigil
                              ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                              by Bonaventure Vigil
                              Dear All,
                              Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                              At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                              12-12-2024, 10:22 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
