aspire 4736z power off after 5sec. it has nec token. i have changed it but same problem. i reflash bios. again same. sio rsm reset and s5 voltage ok. pls anyone help me what to do.
Re: aspire 4736z power off after 5sec
Photos of the Tokin repair? Have you checked for continuity between the +ve and -ve points? A short in this location can give the symptoms you described.Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD -
Check your vcore voltage and try a different CPU.Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSDComment
this is common with this model i also repaired a lot of units by replacing with 4 caps but this auto shutdown problem is very hard to solve i still can not find any solution if any body have something to shere please post hear............thanksComment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Dear All,
Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power.... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
