Remove liquid inside laptop cpu socket S1 AMD
  • Francisco.s
    • 686
    • Spain
    #41
    Re: Remove liquid inside laptop cpu socket S1 AMD
    Originally posted by Dimitrios
    Removed northbridge/gpu ATI 216-0752001 RS880 but short remains on +VDDNBP rail. Can anyone confirm that +VDDNBP power rail is the same with +VDDNB on page 38 of schematics that uploaded earlier??
    I think that the shorted capacitor must be on page 8, bottom left, one of C42, C43 or C49 but cannot locate those cause there is no numbering on the board for most of the capacitors...
    Will try what Atsio mentioned in earlier post.
    As you can see, (page 32) +VDDNBP = +VDDNB.
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      #42
      You are right! How did I miss this?? Thought it was the same!
      Well I am also getting a short 70 Ohm on 1.1VS voltage L13 and L14 so I guess that it's over... I wish I had a regulated lab voltage supply to inject low voltage. Will do in the future but too many shorted components...
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #43
        Well, if you are "writting off" the board, you might as well inject some low voltage and see what gives (take out the RAM, CPU, and anything else valuable before trying, of course).
        I also thought about making a simple and crude current-controlled source, but I haven't tested it yet. Basically, just a big BJT (TO-220 or bigger) attached to a good-sized heatsink, driven by a potentiometer. Since for BJTs, the C-E current is roughly propertional to the B-E current, you should get pretty decent control of the current, IMO. Like I said, though, I haven't tested it.
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Flaku_34
          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
          by Flaku_34
          Introduction:
          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
          04-18-2024, 12:47 PM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • AJ847.63e
          LGA 1700 Socket Replacement Tips & Tricks
          by AJ847.63e
          Hi All,
          Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
          I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
          07-24-2025, 06:57 PM
        • longmt1990
          Panasonic Cf-w5 bios password remove
          by longmt1990
          Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
          I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
          Please help me remove bios password.
          Thank you so much
          07-06-2025, 10:50 PM
